Mill Vice position
Vic03/02/2023 15:40:24
3453 forum posts
23 photos
I have a job coming up that ideally needs my mill vice to be accurately angled at 45° to the table. It’s a plain vice without a swivelling base. Anyone have any quick tips on how I might achieve this?
JasonB03/02/2023 15:43:25
I just put the vice at an angle and clap it down. Usually I can get one stud in the usual place and the other I just use my clamp set for. Put a set square or angle gauge against the fixed jaw and clock that true
If found this image in a good book, although the vice is on it's swivel the scale may not be accurate so I'm clocking it in with an angle gauge and dti, setsquare out of a school geometry set will also do
Edited By JasonB on 03/02/2023 15:53:14
Tony Pratt 103/02/2023 15:53:33
2319 forum posts
13 photos
As Jason B, you can put something with the appropriate angle against the fixed jaw and adjust vice to suit or use trigonometry and a DTI to get your required angle
Tony
Vic03/02/2023 16:57:11
3453 forum posts
23 photos
Thanks Jason, I’ll give that a try. wink
Martin Connelly03/02/2023 19:22:46
2549 forum posts
235 photos
If you put a DTI on the fixed jaw and set to zero then for 45° an X axis movement should equal the Y axis movement. Eg if you move X 50mm then to get the DTI back to zero should require a 50mm Y axis movement.
Martin C
duncan webster03/02/2023 19:58:12
5307 forum posts
83 photos
If you have a DRO it might have an angle setting facility.
Vic04/02/2023 11:45:37
3453 forum posts
23 photos
Sadly I don’t have a DRO on my mill.
