Digital read out
Cross slide digital read out
john fletcher 122/01/2023 15:31:25
893 forum posts
I'm considering fitting an Arcuro Tools Standard digital read out BAR to my Myford Super 7 lathe cross feed. Before re inventing the wheel, has any one already fitted one and would they like to share with me how they mounted it. John
Harry Wilkes22/01/2023 16:12:48
1613 forum posts
72 photos
Hi John I have not fitted Arcuro Tools one I used the Machine DRO embedded one to my S7 link
https://www.machine-dro.co.uk/cross-slide-dro-encoder-upgrade-for-the-myford-ml7-and-super-7-lathe-digital-readout-bolt-on-kit
H
Andrew Tinsley22/01/2023 16:42:40
1817 forum posts
Much as I respect Arc Euro. I would not consider their digital readout. If I were going to spend money on a system then I would go for The Machine DRO type of system with glass or magnetic scales and a combined readout. The 2 or 3 channel readout enables you to do quite a few useful and fancy tricks! If I could not afford this type of system, then I would wait and save up for it, I would not be tempted by the Bar system.
Andrew.
Edited By Andrew Tinsley on 22/01/2023 16:44:20
john fletcher 122/01/2023 17:19:47
893 forum posts
Many thanks chaps for the response. I have already had a look at the club's fitted super 7. I have a small shed and space is a real premium, the lathe is tight to the wall, I can't find a space for the read out panel. Fortunately Its not the brass but the space, I have managed for more than 30 years so not a big problem. John
Pete.22/01/2023 18:34:00
910 forum posts
303 photos
Machine DRO sell small single and double readouts compatible with their various scales they sell
Harry Wilkes22/01/2023 20:59:04
1613 forum posts
72 photos
Posted by Pete. on 22/01/2023 18:34:00:
Plus their embedded version for the S7 cross slide requires no extra room behind the lathe the very reason I went that route
H
Pete.22/01/2023 22:01:41
910 forum posts
303 photos
I'm going to fit the embedded scales to my lathe soon, I can't remember exactly what the price is to upgrade, about £25 per readout to upgrade to 0.001mm resolution, which seems pretty reasonable to me.
This is their single readout, probably about 45mm~50mm high so pretty compact.
Neil Lickfold23/01/2023 08:39:33
1025 forum posts
204 photos
I fitted the embeded magnetic tape , similar to mdro , but mine is from Ditron in China. It comes with a 1um resolution per side reader head and matching tape. so reads 2um. It has been very reliable so far. What I do like with the Ditron is that it has the ability to show RPM and feedrate on any chosen axis. With these types of systems, you can also add the top slide. I find that the arc features are great when you want to make a 1 off radius etc instaed of having to make a form tool that is unlikely to be used again. The downside of the embeded system is that you need a mill to cut the recess for the magnetic tape.
There are many systems out there, and it's not always easy to decide that is for sure.
Martin Johnson 123/01/2023 12:54:56
320 forum posts
I ran a modified digi caliper on my lathe cross slide for a while, but found it really achieved nothing. I work mostly in metric on an imperial lathe and conversion is easy as 2 x table (0.1 mm requires 2 thou on the dial). Eventually it had some problem (cant remember now) and I couldnt be bothered to repair it.
What I do have is a long Arc Euro magnetic bar on the long axis. A very worthwhile mod.
I value the advanced features on my 3 axis Sinpo system on rhe mill, but really don't see that I could justify the expense on the lathe.
Martin
