Creating a set of changewheels
How to go about creating 0.5 module set of changewheels
Mike Waldron01/01/2023 10:18:12
51 forum posts
Happy New Year all!
I have an Adept ordinary lathe that I am upgrading as near to watchmaking quality as possible.
I have read the article from 1947 by L.V.P.Clarke, who did much the same, and used 50DP gears. I’m going to do things in metric, as I am a railway Modeller, so intend to use 0.5 module.
The problem is, I can’t work out what size the set of gear blanks has to be. I have Ivan Law’s Workshop practice book, but try as I might, I can’t find out what size to make each gear blank. I must be missing something important!!
Can anyone point me in the right direction, please?
I want to make a standard set:
20, 25, 30, 35, 40, 45, 50, 55, 60, 65, 70, 75, 90 and 120 Teeth.
Edited By Mike Waldron on 01/01/2023 10:23:16
Edited By Mike Waldron on 01/01/2023 11:20:01
John Rudd01/01/2023 10:25:18
1479 forum posts
Mike,
HPC Gears tables give the overall dimension for various counts….should help as a starter…
https://www.hpcgears.com/pdf_c33/23.10-23.13.pdf
Dave S01/01/2023 10:39:47
433 forum posts
95 photos
I’m away so can’t look it up, but I’m pretty sure the calls are in Ivan’s book.
The diameters relate to the number of teeth and the module size.
I seem to remember it’s something like number of teeth + 1 divided by the module, but that might be pitch centre or totally wrong…
John Haine01/01/2023 10:43:58
5563 forum posts
322 photos
I think it is (N+2)*module. Page 57 of Law's book, LH column.
John Hinkley01/01/2023 10:52:11
1545 forum posts
484 photos
When this question comes upon the forum, I always recommend Geardxf download, a freeware program from forestmoon.com. It not only gives all the gear dimensions you will ever need, but covers DP and MOD gears too and you can export the results to dxf file, as the name implies.
edit: corrected hyperlink
Edited By John Hinkley on 01/01/2023 10:55:52
Brian Wood01/01/2023 11:01:15
2742 forum posts
39 photos
+1 for John Haine. The result is the O/D of each blank, in mm. N is the tooth count
Pete Rimmer01/01/2023 11:32:07
1486 forum posts
105 photos
Mike,
As above, for 0.5mod all you do is take your tooth count, add 2 then divide the result by 2. So your 120 tooth gear would be 61mm diameter.
Mike Waldron01/01/2023 11:58:28
51 forum posts
Very many thanks all for your help!
A first time for everything!
Now I can get going!
DC31k02/01/2023 10:46:58
1186 forum posts
11 photos
Posted by Pete Rimmer on 01/01/2023 11:32:07:
While what you say is true in this particular case, it is a bit of a poor way to express the maths. The division by two is actually multiplication by the module, which in this case just happens to be 0.5.
