New lathe
David Noble23/11/2022 18:39:45
402 forum posts
37 photos
Well, new to me. I was talking to a friend about lathes and engineering in general when he said “I’ve a lathe in lots of pieces and boxes, you can have it if you want to rebuild it”
As you can see, I’m loosely assembling it to see what might be missing. Quite looking forward to doing this.
David
bernard towers23/11/2022 19:15:35
1221 forum posts
161 photos
Looks like theirs some good info and quite a few pictures from different angles on Lathes .co.uk site .Best of luck.
Taf_Pembs23/11/2022 19:20:51
126 forum posts
96 photos
Tidy job David..! Right place right time thumbs up
I'm only new to messing with machine tools, last couple of years - I should have listened to my metal work teacher in school.. he told me to stick with it but motorbikes etc took over and ended up with a bike shop - now seem to be getting more enjoyment out of doing them up a bit rather than using them!
Look forward to seeing it turning..beer
Hopper23/11/2022 22:23:02
7881 forum posts
397 photos
Looks like a little beauty. The thread chaser dial mounted to the left of the carriage instead of the usual right is unique. Easier to watch while keeping an eye on the cutting tool I suppose.
David Noble24/11/2022 08:51:35
402 forum posts
37 photos
Thanks guys, it also has a feed shaft on the back driving saddle and cross slide.
David Noble24/11/2022 10:09:32
402 forum posts
37 photos
c7e22834-354a-4794-b107-714daa3bc797.jpegJust a sanity check please! I need to fabricate the bracket for the motor mounting which is missing. I’ve been looking on-line to see if there are photos of what it should look like and found these. On both photos it looks like the lathe will be running backwards. ( I do realise this post could make me look silly) 😊
Grindstone Cowboy24/11/2022 10:14:24
1160 forum posts
73 photos
Looks good, David.
No, that should work the right way, Myfords, Boxfords and my Taig are all arranged that way round.
If it doesn't, just reverse the motor devil
Rob
Michael Gilligan24/11/2022 11:35:08
23121 forum posts
1360 photos
Posted by David Noble on 24/11/2022 10:09:32:
First let me join the list of admirers, David … That machine has great potential yes
Now; may I suggest that whilst you are busy on the drive system you seriously consider converting it to Poly-Vee
… I think it would be transformational
Jonty Smith24/11/2022 11:49:51
1 forum posts
Good Day
I install a heavy duty lathe from chester machine tools and the chuck does not want to turn when switch on with level
JasonB24/11/2022 12:55:59
Make sure all the safety cut out switches are in operation for example the chuck guard needs to be down and gear train cover properly fitted
David Noble24/11/2022 13:31:17
402 forum posts
37 photos
Posted by Grindstone Cowboy on 24/11/2022 10:14:24:
Looks good, David.
Rob
Thanks Rob,
You will not have known that the motor has a capacitor so not a brushed motor. I didn't think this could be reversed
but as always, I'm happy to be wrong.
David
David Noble24/11/2022 13:35:34
402 forum posts
37 photos
Posted by Michael Gilligan on 24/11/2022 11:35:08:
Thanks Michael,
I hadn't thought about Poly-Vee belts as I've no experience with them. Are they a lot better? I'm presuming that the
original flat belts would be the worst option.
David
Michael Gilligan24/11/2022 15:15:08
23121 forum posts
1360 photos
Poly-Vee belts have the flexibility of a flat belt, and better drive performance than a single Vee belt
  • Pulleys are readily available, and also easy to make
  • Millions of cars and domestic appliances use them
Edit: __ Just one of many suppliers:
https://www.bearingstation.co.uk/products/belts/v-poly/j-section
Edited By Michael Gilligan on 24/11/2022 15:21:05
Bazyle24/11/2022 15:34:34
6956 forum posts
229 photos
It has plain bearings - v-belts are already a step up from the original flat leather so why waste resources on new pulleys. If they slip a bit so what.
Michael Gilligan24/11/2022 15:58:09
23121 forum posts
1360 photos
Posted by Bazyle on 24/11/2022 15:34:34:
For one thing … the drive can be much more compact, because Poly-Vee can safely wrap round small diameter pulleys.
Howard Lewis24/11/2022 16:26:32
7227 forum posts
21 photos
You will be able to do some good work on that machine as you nbecome familiar with it.
IF the motor runs in the wrong direction, reversing should be fairly easy.
Those who know more than I, will give you the detail of how to reverse the connections to the start windings.
Enjoy!
Howard.
Bazyle24/11/2022 19:36:08
6956 forum posts
229 photos
Good point MG.
Michael Gilligan24/11/2022 20:03:55
23121 forum posts
1360 photos
Thanks, Bazyle
