Does this have a name?
Unusual water service valve (and its key).
David Jupp20/11/2022 17:03:21
978 forum posts
26 photos
I've come across a water service valve buried in house wall. It's an isolation for exterior tap, and the only access (without pulling wall apart) is down a small hole perhaps 10mm diameter.
Rather than the standard screwdriver slot to twist the ball, this valve has a raised bar across a rounded dimple.
I speculate that the key/tool to operate it would look like
I've searched on-line for similar valves, or the tool to operate, but have failed to find anything. Does anyone here know a name for valves of this type? or where I can get a key?
I can make a key, but will be largely guesswork as measuring down the access hole is not easy.
Edited By David Jupp on 20/11/2022 17:04:10
Martin Shaw 120/11/2022 17:24:35
185 forum posts
59 photos
Sounds like it might be a 1/4 turn plug cock. Age will determine whether anything is available commercially but I would suggest that it's not recent. When I was working I came across them occasionally as the drain valve for a hot water cylinder and not really suited for high pressure applications, i.e mains water.
Martin
David Jupp20/11/2022 17:38:29
978 forum posts
26 photos
Martin,
Thanks - I'm pretty sure it is a 1/4 turn ball valve, similar to the ones that have a screwdriver slot. I can just make out compression fitting at one side of the valve when peering down the hole in the wall.
I was hoping to find either a key, or details of the valve that I could measure/estimate sizes from to make my own key.
Robert Atkinson 220/11/2022 17:41:11
1891 forum posts
37 photos
That sounds more like the sort of coupling you would find on a motorised valve. I wonder if somone repurposed the valve part of a motorised assembly?
Robert G8RPI.
Dave Halford20/11/2022 19:26:40
2536 forum posts
24 photos
If you can get to the pipe from inside the house, then fit a new valve where you can get at it.
Disturbing an old valve buried inside a wall as asking for trouble.
old mart20/11/2022 20:02:29
4655 forum posts
304 photos
I fully agree with Dave Halford, do not think about turning it. Years ago when fitting central heating to my bungalow, I found the main stopcock in the path didn't want to turn fully off, and I broke it off. I changed the stopcock inside the house with a trickle of water running, helped immensely by the old nut and olive fitting the new tap. The broken stopcock was 2 feet below the surface in a 4" diameter hole. The tap handle had broken at the square end of the brass shaft leaving about an inch projecting. I rushed out to a very good local tool shop and bought set of three 1/2" drive stud extractors, the type that look like a long socket with internal rollers and a 12" extension. Together with my extensions, one of the extractors fitted and turned the stopcock back on. Years later a new main was pushed through about 4 feet deep for all the houses and a brand new plastic stopcock was fitted, all without digging a trench through 120 yards of front gardens, clever, these water board guys are, I thought.
David Jupp21/11/2022 08:55:40
978 forum posts
26 photos
Dave / Old Mart,
The valve is inside a boxed in section of wall just inside the property. There is already a hole for a valve key in the board over the pipe/valve. As the valve is inside (and assuming it to be a 1/4 turn) valve, it is unlikely to have seized - if it has that will become obvious when I attempt (carefully) to turn it.
Replacing the valve would require removing/replacing the boarding, and consequent re-decorating - hence I'd like to try closing the valve through the access hole that was clearly put there for that purpose. It's a pity no key was provided!
SillyOldDuffer21/11/2022 09:22:34
10668 forum posts
2415 photos
Posted by David Jupp on 21/11/2022 08:55:40:
Replacing the valve would require removing/replacing the boarding, and consequent re-decorating - hence I'd like to try closing the valve through the access hole that was clearly put there for that purpose. ...
I don't think the valve being inside has any effect on whether it's seized or not. What matters is the nature of your water, hard soft etc, and - most of all - how long it's been since the valve was last moved.
When my interior stop-cock seized I was able to force it closed but the cock twisted on it's compression fittings, damaged the pipes, and both joints started to drip. I managed to fix that by retightening, but it left the pipes in a precarious state. About a year later, I had to turn off the stop cock again, and the same thing happened except it was impossible to stop the leaks. Fitting a new stop-cock to cleaned up pipes became a nightmare when it turned out the incoming plastic pipe needed an imperial top-hat gland that's unobtainium. (being a metric fanboy, I used 'industrial language' on the idiot who had decided in the early 1970s it was OK to make a modern pipe and seal system in imperial rather than going metric; it seems the imperial version didn't last long, making spare parts hard to find, turning a straightforward job into a pig.
I agree it's worth a try. However, I recommend preparing for the worst! Don't attempt it when the shops are closed, you don't have the right tools, and plumbers are on strike!
David Jupp21/11/2022 09:34:47
978 forum posts
26 photos
Please can we keep this on topic? I'm aware of the risks of seized valves (I judge it unlikely - I could be wrong, risk is on my own head. This is NOT a stop cock - it's a service valve (1/4 turn ball valve)). I do know where the stop cock is, and that isn't seized.
All I'm looking for is if anyone knows a name/term that might help to find a similar valve or the matching key via a search engine (as everything I tried had failed).
I'll probably end up choosing a few different diameter rods from my scrap box, round one end in the lathe, cut a slot with hacksaw then go to site and file to adjust.
Michael Gilligan21/11/2022 09:56:38
23121 forum posts
1360 photos
David
Although I have never seen one quite like you describe … I suspect you have a ‘tamper-proof’ valve which has been usefully re-purposed.
Conceptually similar to the one discussed here: **LINK**
https://terrylove.com/forums/index.php?threads/tamper-proof-angle-stops-argh.36826/
… but obviously differing in detail.
Think of all those annoying screws on modern electrical appliances, or of all the variations on car wheel-nut design.
I think ‘reverse engineering’ a key for what you have is probably the best bet.
Edited after more careful reading of your opening post.
Edited By Michael Gilligan on 21/11/2022 10:02:52
Michael Gilligan21/11/2022 10:21:49
23121 forum posts
1360 photos
Please forgive a slight digression …
Here is a quite informative ‘advertorial’ about ball-valves in general: **LINK**
https://theengineeringmindset.com/the-basics-of-ball-valves-explained/
