Dave Sawdon 1 | 16/11/2022 17:32:47 |
49 forum posts 4 photos | I need to replace the tool post (or "tool clamp post" ) and see that there are 3 grub screws around it in the compound slide. Their points bear on the top of the tool post foot but don't screw into it. What are they for? Dave Edited By Dave Sawdon 1 on 16/11/2022 17:33:09 |
ega | 16/11/2022 17:41:02 |
2805 forum posts 219 photos | Presumably, as with the Sevens, they are for the four way toolpost ratchet. |
Dave Sawdon 1 | 16/11/2022 17:57:22 |
49 forum posts 4 photos | I haven't owned a "7" so don't know what they're like. The grub screws are item 5 in this extract from the 254 parts manual and described as "grub screw - plug" - so are they just plugging holes that can be used by the 4-way toolpost? Mine has the standard clamp, as shown in the picture, but I have a size A Multifix tool post and it looks like this will fit if I sleeve the "clamp post" ... but first I need to replace the bent clamp post! |
Steviegtr | 16/11/2022 18:09:25 |
![]() 2668 forum posts 352 photos | I believe on my Super 7 which has them. It is just to locate the post bolt. Stops it spinning when tightened. I think on mine they were just steel pins. Steve. |
bernard towers | 16/11/2022 18:14:41 |
1221 forum posts 161 photos | 4Way toolpost ratchet screw holes |
bricky | 16/11/2022 18:18:05 |
627 forum posts 72 photos | definately for the ratche base of the four way toolpost. Frank |
Dave Sawdon 1 | 16/11/2022 19:22:41 |
49 forum posts 4 photos | Thanks everyone. I'll be using a Multifix size A toolpost (subject to checking tool height range) so will need to drill a couple of holes for the dowel pins but then will put the grub screws back and stop thinking about them. (Steviegtr: they are in tapped holes in the compound slide but don't penetrate the foot of the tool post. There's a single steel pin to prevent rotation) Dave |
