David Davies 8 | 14/11/2022 22:22:05 |
![]() 202 forum posts 1 photos | Good Evening I have a strange problem with a recently acquired Albrecht 1/2 inch chuck and before I pull it to bits I wonder whether anyone has seen this behaviour before? Holding the chuck in my hand, if I insert a drill bit and tighten it securely using both hands, the moment I release my grip on the hood it unwinds and loses its grip on the drill.. This happens on both 7mm and 11.5mm diameter drill bits. Any thoughts? Thanks Dave |
Tony Pratt 1 | 14/11/2022 22:26:08 |
2319 forum posts 13 photos | Try a very thorough degrease Tony |
David Davies 8 | 16/11/2022 18:48:13 |
![]() 202 forum posts 1 photos | Thanks Tony, I'll give that a try first. Cheers Dave
Simon Williams 3 | 16/11/2022 19:19:44 |
728 forum posts 90 photos | You might like to take a look at Tom Lipton with much the same question - though not quite as severe. Try Youtube link here He makes the point that the gripping efficiency of an Albrecht chuck is a compromise between a bit of lubrication to get the tightening to work, but too much lubrication stops the friction necessary to hold the drill securely. He also details how to get the thing to bits and what to expect to find inside. Good luck Simon |
David Davies 8 | 16/11/2022 21:40:52 |
![]() 202 forum posts 1 photos | Thanks for the link Simon, very interesting! |
JohnF | 17/11/2022 23:25:14 |
![]() 1243 forum posts 202 photos | David, Have a look at this link to overhauling these chucks on Machinists Blog John Edited By JohnF on 17/11/2022 23:25:45 |
Ady1 | 17/11/2022 23:40:11 |
![]() 6137 forum posts 893 photos | I did a cheapo one of theirs here |
Kiwi Bloke | 18/11/2022 09:23:52 |
912 forum posts 3 photos | Really useful info, thanks. I hadn't appreciated the importance of a bit of appropriate friction in these things. |
David Davies 8 | 19/11/2022 08:36:49 |
![]() 202 forum posts 1 photos | JohnF and Ady1, thanks for your posts, both very helpful.
