Elliott TV2 Milling Machine
Jan Raap13/11/2022 11:09:55
21 forum posts
32 photos
I have recently picked up my first milling machine. It is an Elliott TV2 milling machine which I think is from the 1960's.
Information on the machine is very hard to come by but it looks like the head is similar to the Elliott Omnimill 01 & 02 Milling Machines. The base looks similar to the Elliott MILMOR Turret Milling Machines.
The lathes.co.uk lists a manual but I have been informed that it is mostly marketing information with very little information on the machine itself.
I would be very grateful if anybody can give me more information on the machine or provide any of the three manuals (TV2 or Omnimill 01 &02 or MILMOR) so I can piece things together.
See below for a few photos of the machine.
We had to remove the slotter's motor and rotate the vertical head 90 degrees to get it into the garage.
Edited By Jan Raap on 13/11/2022 11:11:23
Tony Pratt 113/11/2022 13:01:36
2319 forum posts
13 photos
Sorry but I can't help with manuals but looks a useful machine! Out of interest how did you get it in and out of your pick up?
Tony
not done it yet13/11/2022 13:37:33
7517 forum posts
20 photos
That is reported to weigh approx 1.2 tonnes! Quite a lot for a pick up?
Bazyle13/11/2022 15:44:08
6956 forum posts
229 photos
Be sure to join the Elliott group on Groups.io It is a very quiet forum but has some files and helpful individuals.
Dave Halford13/11/2022 16:47:21
2536 forum posts
24 photos
Can't fault your bravery smiley
Jan Raap13/11/2022 17:22:59
21 forum posts
32 photos
Posted by Tony Pratt 1 on 13/11/2022 13:01:36:
Tony
The seller had a forklift truck and we just about managed to load the machine on the back with the relatively short forks. I did not have a concrete plan to get the machine off at home. Luckily my neighbour across the road spotted me pulling in and he offered to offload the machine with a tractor he had access to on the farm he worked. Saved me hours upon hours stripping the machine down to get it off.
Posted by not done it yet on 13/11/2022 13:37:33:
The seller estimated the weight to be 500kg before I went to pick it up. Clearly, that was way off. I am still not sure what the exact weight is but it is fair to say it was definitely on the limit for the Ford Ranger and not a load I would like to carry again.
Jan Raap13/11/2022 17:25:24
21 forum posts
32 photos
Posted by Bazyle on 13/11/2022 15:44:08:
I have tried, but  'Your subscription has not yet been approved.'. I am not sure if anybody monitors it anymore
Edited By Jan Raap on 13/11/2022 17:25:46
Jan Raap18/11/2022 22:07:13
21 forum posts
32 photos
Rick Moore kindly scanned his copy of the manual and sent it to me.
Unfortunately, it does not have a detailed breakdown of the machine, there must have been an additional 'parts' manual too.
I am still happy that Rick was kind enough to scan his manual and send it on.
Elliott Victoria TV2 Milling Machine Operator Manual.
Edited By Jan Raap on 18/11/2022 22:08:19
Jan Raap09/12/2022 16:05:43
21 forum posts
32 photos
I made a quick raw video of the milling machine. Everything seems to work.
Dave Halford09/12/2022 16:31:40
2536 forum posts
24 photos
Posted by Jan Raap on 18/11/2022 22:07:13:
That is pretty much all you ever get with any industrial machine. Elliotts would have such a document to build the machine, but it wouldn't leave the works.
DC31k09/12/2022 17:14:10
1186 forum posts
11 photos
Posted by Dave Halford on 09/12/2022 16:31:40:
I am not sure that is correct as a general statement.
Look at any Colchester lathe manual: it has a complete parts breakdown with every nut, bot and washer itemised.
Would you consider a Bridgeport mill an 'industrial machine'?
https://www.hardinge.com/wp-content/uploads/KneeMill-Parts-Older.pdf
I think all that can be said is that some manufacturers provided less information to their customers than others.
Jan Raap09/12/2022 17:27:26
21 forum posts
32 photos
I am sure there was a parts manual too. Interestingly, I also have an Elliot Omnispeed lathe and that manual provides way more detail than the TV2.
It looks like Elliott did not take the same approach to all of their machines.
Nigel McBurney 109/12/2022 19:17:47
1101 forum posts
I used to have a Mlmor,a lot heavier machine,around 1 and 3/4 tons with 50 inch table ,it would have your pickups front wheels in the air. I did aquire a hand book, not very informative ,no mention of the spindle lubrication,or bearing adjustment etc. My current mill is a Elliott 00 omni mill which came with sales leaflet and handbook, which had more info than the milmor but not brilliant ok for lubricating info and machine dimensions and detail parts breakdown,check the head tram fairly often ,the heads do move under heavy cutting.though these Elliott machines do have lots of travel on xyz axis and good clearance under the spindle,I note that yours has a riser block for more spindle clearance,similar to the Bridgeport.I would not pay a lot of cash for a handbook not really worth having,
