Michael Callaghan | 03/11/2022 22:13:49 |
173 forum posts 7 photos | Hi, can anyone please explain to me the method of setting valve timing by blowing into the locomotives cylinders please. Thanks |
bernard towers | 04/11/2022 18:17:49 |
1221 forum posts 161 photos | I had a friend who did his timing by using jars filled with water and tubes from the exhaust into these jars thereby pinpointing the exact time the exhaust opened. |
Michael Callaghan | 04/11/2022 19:28:17 |
173 forum posts 7 photos | Thanks. That’s the sort of information I was looking for. |
Jon Lawes | 04/11/2022 19:42:17 |
![]() 1078 forum posts | Following a recent thread on the subject on a different site I think you can get a better feel by attaching a tube to the drain cocks and gently sucking. |
Michael Callaghan | 04/11/2022 20:08:21 |
173 forum posts 7 photos | Now that’s a good idea thanks jon |
bernard towers | 05/11/2022 12:08:36 |
1221 forum posts 161 photos | I think the bubbles in the jar of water is more accurate. |
Paul Lousick | 06/11/2022 07:14:39 |
2276 forum posts 801 photos | Timing should be done when the engine is hot and parts have expanded. (And I would not recommend sucking, especially on a large/full size engine with steam and oil) |
JasonB | 06/11/2022 07:25:41 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by bernard towers on 04/11/2022 18:17:49:
I had a friend who did his timing by using jars filled with water and tubes from the exhaust into these jars thereby pinpointing the exact time the exhaust opened. If the exhaust opens before the inlet due to lap how does blowing show when the exhaust is open? Unless you are blowing into th edrains and not the inlet. If you suck from a drain cock you will draw in air through the exhaust regardless of whether the inlet is open or not. Like wise sucking on the drain cock with eh exhaust blanked off will indicate when the inlet opens. If you want to use water in jars and avoid sucking in something nasty have a sealed jar with two connections - one for a pipe to go into the water and another above the water to suck. I also doubt that any blowing into the cylinders via drain cocks would work, at least not on a slide valve setup as the valve would just lift, may be OK on piston valves. Edited By JasonB on 06/11/2022 07:32:31 Edited By JasonB on 06/11/2022 07:46:55 |
