What thread
David George 119/10/2022 10:34:32
2110 forum posts
565 photos
Just been asked what thread is in these 10mm tools my friend has a set of these indexable tool holders but the screws are poor and has had to butcher the head to get the screw out because the star is worn. I cannot find a similar screw which measures 3.5mm ish with a 0.8mm pitch. If anyone has any information of what thread or where screws can be bought from. The body of the holders are very hard you can not file them and no way can you tap them.
David
Edited By David George 1 on 19/10/2022 10:35:56
Brian Wood19/10/2022 10:46:14
2742 forum posts
39 photos
David,
Try Jenny Blackwell of J B Cutting Tools [phone 01246 418110] The screws are known as tip screws and can be supplied with the correctly fitting Torx head wrench, small ones with a 'flag' type side grip to limit the torque you can apply
3.5 mm x 0.8 mm is a standard metric thread and you should be able to run a tap down the female part to clear out debris
Oldiron19/10/2022 11:30:43
1193 forum posts
59 photos
A couple of years ago I bought a few different indexable tip holders from a sale at an engineering works. They came with a couple of 125mm long right angle torx spanners. All of the screws holding the tips in were so tight I had to drill most of the heads off and resort to Mole grips to remove the screws. The screws really do not need to be very tight. The little plastic flag on the torx tool only needs a little thumb and finger pressure to get to the correct torque setting.
+1 for JB Cutting Tools. Jenny has always been helpful when contacted. I bought quite a few indexable tips from her at the MMEE on the Friday.
regards
David George 119/10/2022 11:35:22
2110 forum posts
565 photos
Rang Jenny and yes she has those in stock in the post today.
Thanks
David
