Martin King 2 | 29/09/2022 12:15:30 |
![]() 1129 forum posts 1 photos | Hi All, I have a very nice antique diamond Point glass cutter that sadly is missing its diamond. Does anyone know how this might be replaced as I have several other scrap ones that could donate a diamond? Looks a bit like solder? |
Clive Brown 1 | 29/09/2022 12:22:15 |
1050 forum posts 56 photos | I think that you can use a low melting point alloy called "Cerro Matrix" which expands when it solidifies. That's what my FiL, who was a grinding expert, used for wheel dressers. |
Martin King 2 | 29/09/2022 12:57:14 |
![]() 1129 forum posts 1 photos | So perhaps gently melting the tip where the diamond was, the dropping in the replacement might work? Also probably the way to remove the point that will be used from the old cutter? Cheers, Martin |
Michael Gilligan | 29/09/2022 13:03:10 |
![]() 23121 forum posts 1360 photos | Very likely, Martin Noting also that “Cerro Matrix” is probably in the same family as CerroBend … but may well be a slightly different [tougher?] formulation of alloy. MichaelG. |
Speedy Builder5 | 29/09/2022 16:53:04 |
2878 forum posts 248 photos | You could use one of these ? |
David George 1 | 29/09/2022 17:28:08 |
![]() 2110 forum posts 565 photos | I made one from a piece of silver steel which I drilled the end deeper than the diamond but a loose fit. I dropped the diamond in with some flux and with it held down with a titanium pin I silver soldered over the diamond with a low temperature silver solder. After it had cooled I ground back the end with a champher till the tip was sticking out. The body of the diamond which was still held by the solder was holding the diamond in situ. Hope this helps. David |
Michael Gilligan | 29/09/2022 18:36:34 |
![]() 23121 forum posts 1360 photos | A little bit of history here: **LINK** https://www.aviationancestry.co.uk/?home/&searchQuery=MiningAndChemical&startYear=1909&endYear=1990&&searchOrder=ASC&pageNum=2 MichaelG. . Edit: __ is anyone sufficiently interested to go searching for the document referenced here: ? Edited By Michael Gilligan on 29/09/2022 18:54:53 |
