Removing fine burrs
Steve Crow15/08/2022 18:16:22
429 forum posts
268 photos
I've cut a number of small clock wheels.
I find that when I try to clean up/polish the face of the wheel, whatever method I use, it throws up very fine burrs on the teeth.
I've tried adhesive lapping film stuck to glass (a method I use for sharpening my leather knives) and fine wet and dry but I still get a tiny burr.
Has anyone any suggestions for a method for this?
I keep hearing about Carat paper used by jewellers. Is that a solution?
George Daniels recommends flattened Water of Ayr stone under running water. Good luck to anybody trying to get that!
Cheers,
Steve
Edited By Steve Crow on 15/08/2022 18:16:37
John Haine15/08/2022 18:43:43
5563 forum posts
322 photos
Running water or the stone?
I use a Noga deburrer and a triangular scraper.
Iain Downs15/08/2022 18:58:52
976 forum posts
805 photos
I believe (though only through what I've read), that the correct approach is some pegwood and fine grinding paste.
Iain
Martin Kyte15/08/2022 19:14:37
3445 forum posts
62 photos
A good modern substitute for Water of Ayr stone, now the mine has closed, is a Shah stone.
Personally I would not worry over much. The burrs will disappear with first meshing with the pinions. Of course if you are making Daniels grade watches that may be different.
regards Martin
bernard towers15/08/2022 22:24:47
1221 forum posts
161 photos
Try tumbling , there are various mediums for different materials and degrees of aggression
Neil Lickfold16/08/2022 09:27:06
1025 forum posts
204 photos
The very light grey scotchbrite pads, are very good for removing fine burs on all sorts of things, brass, steel, Al, copper etc.
Martin Kyte16/08/2022 09:59:05
3445 forum posts
62 photos
What grit are you going down to when you are finishing. The wheels you show are no where near polished. You need to go to at least 5 micron or 1200 grit and then some. Finish of with Autosol.
regards Martin
Steve Crow16/08/2022 10:08:55
429 forum posts
268 photos
No, I haven't started on these wheels yet, they are straight from the milling machine.
I have tried beyond 1200 but a tiny burr remains on the teeth.
Steve Crow16/08/2022 11:05:44
429 forum posts
268 photos
Posted by Martin Kyte on 15/08/2022 19:14:37:
regards Martin
Thanks Martin. When I've finished making my depthing tool, I'll give them a good run round with a pinion and see if that does the trick.
