John Rutzen | 01/08/2022 08:30:45 |
411 forum posts 22 photos | Hi, I want to build a model of an old French 2-4-0, one of it's features is a very large dome nearly the diameter of the boiler. I have been wondering how to make this and remember reading some articles in ME a few years back on making an early aero engine and the writer electroformed the cylinder water jackets. The problem is I can't find it. Can somenone please tell me where the articles are? I've looked in the index but no results. Thanks! |
Nigel Bennett | 01/08/2022 08:41:37 |
![]() 500 forum posts 31 photos | Stephen Wessel's ENV aero engine. ME 4577, 4579, 4581 refer (2018) |
John Rutzen | 01/08/2022 10:46:20 |
411 forum posts 22 photos | Thanks Nigel, that's the one. I thought it was an Antoinette which explains why I couldn't find it. |
noel shelley | 01/08/2022 10:56:51 |
2308 forum posts 33 photos | An interesting process ! but casting might be easier, though for this item. The thickness would leave you with a very thin and easily damaged component in soft copper. One might also consider beating it out of sheet. Keep us posted. Noel. |
John Rutzen | 01/08/2022 12:11:04 |
411 forum posts 22 photos | Hi, I've thought of spinning it from a piece of 3 inch copper tube which i happen to have but I don't know how to spin something inwards. I've managed to spin a dome from a sheet but not this size. LBSC says bash it out from sheet but I've always suspected that he over simplified how to do things! |
Hopper | 01/08/2022 13:12:58 |
![]() 7881 forum posts 397 photos | Copper should be easy enough to bash out from sheet using a sandbag and domed hammer etc then moving to a former of some sort for finishing maybe. You would have to keep annealing it as you went I should imagine. Herbert Dyer, a prolific contributor to ME for about 50 years, wrote a good book on the subject that is still available secondhand at reasonable prices if you shop around a bit (and avoid Amazon!). LINK |
John Rutzen | 02/08/2022 07:28:40 |
411 forum posts 22 photos | Nigel, I haven't got the first of those articles. Would it be possible please to send me a copy of the article or if not could you see if there are specific instructions in it as to how to mix the electrolyte? |
lee webster | 02/08/2022 17:17:38 |
383 forum posts 71 photos | John, I have watched several youtube videos where a dome is formed in metal using hydraulic pressure. Two thick steel plates with the copper sheet sandwiched between. The top plate has a hole the diameter of the dome, the bottom plate has a hole for a grease nipple. When the whole lot is bolted together and a grease gun is used to pump grease into the former, the copper, properly annealed, should start forming a dome. I have seen a video where a headlight for a motorbike was formed this way. Lee |
John Rutzen | 02/08/2022 18:28:22 |
411 forum posts 22 photos | That;s interesting Lee, I've someone use a sandwich of wood and bashed the dome shape into thin steel with a mallet. |
lee webster | 02/08/2022 18:39:47 |
383 forum posts 71 photos | John, Some of the domes I have seen formed were over a foot wide, in steel. They weren't a half round though, it was the making of a musical instrument called a hand pan. Nice sound. Lee |
noel shelley | 02/08/2022 20:53:38 |
2308 forum posts 33 photos | A few years ago I bought a rothenberger boiler test pump from a fellow, he was neither a plumber or boiler inspector so I what he had used it for - he showed me some very interesting 2 stroke expansion boxes. You drew a development of the shape cut it out of may be 18 or 20 gauge steel sheet, welded the edges together with a hydraulic fitting in one end and then just blew it up ! equal pressure at all points so no wrincles - perfect ! Once you got the sheet thickness right it would be easy. Nornal hydraulics will run at 2500psi and hand pumps to 10,000psi so there is HUGE force available ! Noel. |
Martin Johnson 1 | 03/08/2022 13:03:46 |
320 forum posts 1 photos | One full size loco I worked on had the dome made in 2 pieces - a hemisphere top silver soldered or brazed to a cylinder. The joints were caxtellated and easily seen close up. The bottom of the cylinder was flared to sit on the boilrt. Martin |
Andrew Tinsley | 03/08/2022 15:33:26 |
1817 forum posts 2 photos | All you need is a former and some sheet gilders metal. Very easy to use if you have even rudimentary panel beating skills. Andrew. |
V8Eng | 03/08/2022 16:38:52 |
1826 forum posts 1 photos | I think that Jewellers use things called Doming Blocks and Punches but I do not know if they come in large enough sizes or would suit your purpose. Might be worth looking into the idea with jewellery tool suppliers (or make your own?). Edited By V8Eng on 03/08/2022 16:44:08 |
John Rutzen | 03/08/2022 17:49:33 |
411 forum posts 22 photos | I hadn't thought of gilders metal. Is that an alloy of copper? |
Tim Stevens | 03/08/2022 18:52:15 |
![]() 1779 forum posts 1 photos | I know it as gilding metal - it might help to find a source. It is a copper alloy which works rather like silver, less inclined to split as brass can. Heat to redness to anneal, and if possible, leave in the work-hardened condition if the part is subject to attack by housewives or small children. There are Jewellers Supplies firms which are likely to carry stock of sheet. Cheers, Tim |
Nick Clarke 3 | 04/08/2022 09:42:09 |
![]() 1607 forum posts 69 photos | Posted by Tim Stevens on 03/08/2022 18:52:15:
I know it as gilding metal - it might help to find a source. It is a copper alloy which works rather like silver, less inclined to split as brass can. Heat to redness to anneal, and if possible, leave in the work-hardened condition if the part is subject to attack by housewives or small children. There are Jewellers Supplies firms which are likely to carry stock of sheet. Cheers, Tim Try Edwards Metals in Birmingham - They list it. |
