Increasing the working height of a K&W Facing Borer
Ches Green UK | 29/07/2022 10:42:36 |
181 forum posts 7 photos | Not exactly home workshop equipment but an interesting insight in to how the 300 mm high block was made (out of 20 mm plate), welded and skimmed.... https://www.youtube.com/watch?v=roMzviZ4p6I That's a heck of a parting off tool! Part II (the installation) to follow soon, I believe. Ches |
David George 1 | 30/07/2022 08:04:06 |
![]() 2110 forum posts 565 photos | Having worked similar machines it gives me a feeling of how small my little machines are, what I am missing, and what we used to do to to arrive at a finnished job. David |
sean logie | 30/07/2022 08:21:21 |
![]() 608 forum posts 7 photos | Posted by Ches Green UK on 29/07/2022 10:42:36:
Not exactly home workshop equipment but an interesting insight in to how the 300 mm high block was made (out of 20 mm plate), welded and skimmed.... https://www.youtube.com/watch?v=roMzviZ4p6I That's a heck of a parting off tool! Part II (the installation) to follow soon, I believe. Ches Kurt has some wonderful older machines that will soon be a regular part of his channel .He won't please the purists but his end results are what matter . The KW facing borer did a fine job of facing the riser . Sean |
Ches Green UK | 30/07/2022 08:47:35 |
181 forum posts 7 photos | David, Yes, I occasionally worked on larger machines in my youth...the big mills I was fine with, but the big lathes I was very wary off. Sean, Kurt seems one of these motivated people that gets things done. I'm curious to see where/how the block fits into the Borer. I imagine the original designers of the Borer did their stress calcs on all bolted interfaces...I hope the riser lasts the course...it certainly looks substantial. Ches. |
David George 1 | 30/07/2022 09:22:09 |
![]() 2110 forum posts 565 photos | I worked on a huge old flatbed lathe to turn recceses in gearbox covers for a Dosco heading mining machine. The plates were 5 feet long about 2 feet wide and 1/2 inch thick with three overlapping recesses in one side about a 1/4 inch deep The lathe had riser blocks about 18 inch too swing the plate the center recess was ok ish but the outer recesses were a bit hairy swinging a 5 foot plate in an offsett jig bolted to a faceplate like a large blade. There was a back guard with a small radial upstand but there was no front cover. At full swing it had a circumference of about 8 feet swing. I also had to make a sine table with a 3 feet square top and bottom plates 2 inch thick plates, to machine a door for a nuclear reactor made from 1 inch thick stainless steel plate fabrication hollow and filled with lead. It weighed about one and a half tonne. David Edited By David George 1 on 30/07/2022 09:24:16 |
Ches Green UK | 30/07/2022 10:05:25 |
181 forum posts 7 photos | swinging a 5 foot plate That must have been quite a thing. Was there a counterweight, or was the cutting speed low enough that one wasn't needed? Ches |
