Bob Unitt 1 | 28/07/2022 16:54:06 |
![]() 323 forum posts 35 photos | I made a pair of gunmetal bearing standards 4 thou too short vertically. I have some 4 thou brass shim, what's the best way to attach the brass to the gunmetal ? |
old mart | 28/07/2022 17:31:24 |
4655 forum posts 304 photos | You could soft solder them or use epoxy resin after abrading the mating surfaces with fine wet and dry paper. |
bernard towers | 28/07/2022 18:17:58 |
1221 forum posts 161 photos | plus one for soft soldering. |
duncan webster | 28/07/2022 19:02:47 |
5307 forum posts 83 photos | If there are bolts through the pedestal base to hold it down you don't need to attach the shim |
Bob Unitt 1 | 29/07/2022 19:32:01 |
![]() 323 forum posts 35 photos | Posted by duncan webster on 28/07/2022 19:02:47:
If there are bolts through the pedestal base to hold it down you don't need to attach the shim Doh ! And thanks for all the other suggested solutions folks, much appreciated. |
roy entwistle | 30/07/2022 09:08:31 |
1716 forum posts | 4 Thou short, does it matter ? Roy |
Bob Unitt 1 | 30/07/2022 10:11:00 |
![]() 323 forum posts 35 photos | Posted by roy entwistle on 30/07/2022 09:08:31:
4 Thou short, does it matter ? Roy Probably not, but I don't know enough about it to be sure of that, |
Neil Lickfold | 30/07/2022 14:24:55 |
1025 forum posts 204 photos | You can also use super glue to hold in place while assembling, or use Loctite adhesives like the 648 or 620, but 620 is very slow to properly set. Deburr your shim and try to keep it flat as possible. It will only need glue on the outer perimeter, and try to keep it away from the screw holes. A small amount of Oring grease around a hole on the part and around the hole of the shim, is usually enough to stop the glue from wicking to the threads. Edited By Neil Lickfold on 30/07/2022 14:26:56 |
Bob Unitt 1 | 30/07/2022 14:56:42 |
![]() 323 forum posts 35 photos | Thanks Neil. Does anyone happen to know how thick a layer of superglue is ? (or solder ?) |
JasonB | 30/07/2022 16:25:41 |
![]() 25215 forum posts 3105 photos 1 articles | As Roy says it won't make much difference if it's a horizontal engine, if vertical there is usually a bit of adjustment on the piston rod length. If unsure of thicknesses then solder on something a bit thicker and machine back to what's required |
Neil Lickfold | 30/07/2022 21:20:21 |
1025 forum posts 204 photos | Posted by Bob Unitt 1 on 30/07/2022 14:56:42:
Thanks Neil. Does anyone happen to know how thick a layer of superglue is ? (or solder ?) Super glue and 620 can be as thin as 0.01mm, and if the surfaces are flat enough, then down to 0.005mm |
Bob Unitt 1 | 31/07/2022 13:49:56 |
![]() 323 forum posts 35 photos | Posted by Neil Lickfold on 30/07/2022 21:20:21:
Thanks Neil. Does anyone happen to know how thick a layer of superglue is ? (or solder ?) Super glue and 620 can be as thin as 0.01mm, and if the surfaces are flat enough, then down to 0.005mm Thanks. |
