Y C Lui | 14/07/2022 09:00:18 |
84 forum posts 35 photos | My Emco Compact 8 lathe is equipped with a ER25 collet chuck which can hold workpieces of diameter up to 16 mm. The spindle has a MT3 taper bore so it should be possible to put in a MT3 ER32 milling arbor to hold larger workpieces. I am wondering if this is a good idea because if this works Emco would not have made a collet chuck. Inquiring mind will appreciate some answers . |
Paul Lousick | 14/07/2022 09:20:23 |
2276 forum posts 801 photos | The collet chuck will allow you to pass long pieces thru the spindle bore. A 3MT-ER32 will hold larger diameters but not pass anything thru the bore. Both have their advantages. An ER32 collet chuck is a better option Edited By Paul Lousick on 14/07/2022 09:21:48 |
Clive Brown 1 | 14/07/2022 09:23:00 |
1050 forum posts 56 photos | Presumably your collet chuck allows long pieces of bar to pass through the spindle.A chuck which is mounted on an MT would prevent this |
Emgee | 14/07/2022 09:23:46 |
2610 forum posts 312 photos | Sounds OK for short work pieces, but check the MT3 socket will take a full length MT3 taper because many of the 5 series spindles need a reduction for a small length of the taper diameter at the small end. Emgee |
bernard towers | 14/07/2022 11:04:20 |
1221 forum posts 161 photos | Make your own spindle mounted collet chuck or buy an er25 flange mount collet chuck and make a backplate , also get oversize collets to 20 mm. |
Paul Lousick | 14/07/2022 11:20:23 |
2276 forum posts 801 photos | Bernard. The first line of the post states " My Emco Compact 8 lathe is equipped with a ER25 collet chuck" Edited By Paul Lousick on 14/07/2022 11:21:27 |
bernard towers | 14/07/2022 12:39:18 |
1221 forum posts 161 photos | SORRY MISREAD |
DC31k | 14/07/2022 14:25:46 |
1186 forum posts 11 photos | If you go for a MT3-mounted chuck, you will need a drawbar if you are to subject it to anything but axial compression loads. |
old mart | 14/07/2022 17:05:45 |
4655 forum posts 304 photos | You might be able to get a MT3 er40 collet chuck if larger size is important. |
