Dart Reverser nut.
Steve Bright 2 | 03/07/2022 08:02:12 |
26 forum posts 24 photos | Hi all, Looking at the drawings for Martin Evans Dart Reverser nut it says 'Turn from solid gunmetal' Should I follow the drawings or can I get a block of gunmetal.and add the pins? |
Michael Gilligan | 03/07/2022 08:09:41 |
![]() 23121 forum posts 1360 photos | If you insert pins … what material would you use ? Presumably the integral gunmetal ‘pins’ provide some sort of bearing. MichaelG. |
Steve Bright 2 | 03/07/2022 08:23:13 |
26 forum posts 24 photos | I'd use gunmetal and they are guide pins that run in holes on the reverser arm, the top pin runs in a slot in the reverser stand. |
Michael Gilligan | 03/07/2022 08:46:35 |
![]() 23121 forum posts 1360 photos | Should be fine then MichaelG. |
Clive Brown 1 | 03/07/2022 09:23:44 |
1050 forum posts 56 photos | Posted by Steve Bright 2 on 03/07/2022 08:23:13:
I'd use gunmetal and they are guide pins that run in holes on the reverser arm, the top pin runs in a slot in the reverser stand. Aren't they a bit more than guide pins? They presumably transfer the load from the nut to the reversing arm hence to the valve gear and so need to be reasonably sturdy. Agree, the top pin is basically a position indicator and so is not heavily loaded.
Edited By Clive Brown 1 on 03/07/2022 09:26:25 |
Weary | 03/07/2022 09:33:07 |
421 forum posts 1 photos | 'Dart' builders and owners over on Model Engineering Clearing House can almost certainly give you suggestions and advice based on experience. Phil |
SillyOldDuffer | 03/07/2022 09:59:17 |
10668 forum posts 2415 photos | Turning the studs from solid has advantages:
I often use pins because they save time and material. Nonetheless, I'd follow the drawing in this example. Unusually, it looks like delivering the better result for less trouble. Dave |
Michael Gilligan | 03/07/2022 10:42:28 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 03/07/2022 09:59:17:
Turning the studs from solid has advantages: […] I'd follow the drawing in this example. Unusually, it looks like delivering the better result for less trouble. . I agree completely, Dave … I just assumed that Steve was asking because [perhaps] he already had the smaller material to hand. MichaelG. |
Andrew Johnston | 03/07/2022 11:25:11 |
![]() 7061 forum posts 719 photos | It would be a right royal PITA to set up and machine the three spigots in the correct places. I would machine the basic block to size and then drill through for the 3/16" spigots, plus a blind hole for the 1/8" spigot. Then silver solder in a length of rod for the 3/16" spigots and a shorter one for the 1/8" spigot. If it was felt necessary to stick with a Whitworth thread form I would screwcut it rather than try and find a LH tap. Alternatively I would make the thread M10 for which LH taps are readily available, albeit at a price. Andrew |
Clive Brown 1 | 03/07/2022 13:18:39 |
1050 forum posts 56 photos | Agree that machining from solid would be tedious. Although the "Dart" drawing calls for that, Martin Evans used the built up method in eg. "Simplex". Mine's made this way, and it's withstood a lot of winding on up and down tracks. (Apologies for being sideways). |
Baz | 03/07/2022 13:52:28 |
1033 forum posts 2 photos | Don’t see what’s so difficult machining it from the solid, it’s not as though you’re on bonus and got 100 per day to make, nice little job for a small four jaw chuck and a happy hour or so machining. |
Steve Bright 2 | 03/07/2022 14:46:47 |
26 forum posts 24 photos | I'm still undecided. It can be machined from solid, I'd start with a piece of 5/8 x 1" x 1 1/16" long bronze or gunmetal and with some careful setting up it can be machined as a solid. Getting a piece of 3/4" square is easier and drilling then silver soldering the pins in is easy enough. I have looked at FleaBay and 3/8" LH Whitworth taps and dies are readily available and not too bad a cost, but as it would likely be a one off use I would seriously consider machining the threads and I already have the correct HSS tool bit. Hardest part would be holding it after soldering the pins as there isn't a lot to grip. That would be a very good reason to machine from solid and turn the pins after cutting the thread, I have a while before the decision is required so I can ponder it for a while. Thanks for all the replies which have given me food for thought.
Baz | 03/07/2022 15:48:41 |
1033 forum posts 2 photos | Posted by Steve Bright 2 on 03/07/2022 14:46:47: Hardest part would be holding it after soldering the pins as there isn't a lot to grip.
Put a couple of washers over the pins and clamp on them and you have all the grip you need. |
SillyOldDuffer | 03/07/2022 16:49:15 |
10668 forum posts 2415 photos | Posted by Andrew Johnston on 03/07/2022 11:25:11:
It would be a right royal PITA to set up and machine the three spigots in the correct places. Andrew I have to bow to Andrew's much superior experience, but the part doesn't look hard to make from solid to me! Is there a well-hidden booby trap? (I assumed starting from square unless that's cheating!) I'll have a go later if I can find some time amidst all the other distractions. Due to lack of discipline and family intrusions I already have about 15 unfinished projects on the go. Dave
Nick Clarke 3 | 03/07/2022 17:24:34 |
![]() 1607 forum posts 69 photos | Posted by SillyOldDuffer on 03/07/2022 16:49:15:
I'll have a go later if I can find some time amidst all the other distractions. Due to lack of discipline and family intrusions I already have about 15 unfinished projects on the go. Dave Pah! Amateur!! Your unfinished project list ought to be in at least 3 figures if lack of discpline and family were really causing issues!! |
old mart | 03/07/2022 20:45:08 |
4655 forum posts 304 photos | Since the block is not too big, the cost saving from adding pins would not be much. I agree that the one piece block would be strongest and using a four jaw independent chuck in the lathe would be easy to make 90% of it. |
JasonB | 03/07/2022 20:56:05 |
![]() 25215 forum posts 3105 photos 1 articles | Starting with some round stock about 28mm dia in the 3-jaw would make it easy to turn the two spigots on opposite sides so they are concentric then square up three other sides and turn the final top spigot. Or a longer bit of rectangular stock would allow one spigot to be turned with conventional tools and the other with a parting tool all at the same setting which would again keep the two spigots concentric |
Andrew Johnston | 03/07/2022 21:23:45 |
![]() 7061 forum posts 719 photos | Posted by SillyOldDuffer on 03/07/2022 16:49:15:
...the part doesn't look hard to make from solid to me! I didn't say it was hard, or difficult, but a PITA. Making it from solid means that 3 three points have to be marked out and then picked up on in the 4-jaw chuck. Presumably the 3/16" spigots need to be concentric, so need to be picked up to a high degree of accuracy. Drilling a hole and silver soldering in a pin is simpler and guarantees concentricity. A sliver soldered pin will be as strong as solid. Andrew |
julian atkins | 03/07/2022 22:07:03 |
![]() 1285 forum posts 353 photos | I would have a look at the GWR drawings, and start from there. There are significant issues with the Martin Evans 'Dart' design. Is the valve gear on 'Dart' capable of being 'notched up ' anyway? |
JasonB | 04/07/2022 06:52:30 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Andrew Johnston on 03/07/2022 21:23:45:
...the part doesn't look hard to make from solid to me! I didn't say it was hard, or difficult, but a PITA. Making it from solid means that 3 three points have to be marked out and then picked up on in the 4-jaw chuck. Presumably the 3/16" spigots need to be concentric, so need to be picked up to a high degree of accuracy. Drilling a hole and silver soldering in a pin is simpler and guarantees concentricity. A sliver soldered pin will be as strong as solid. Andrew Not if done as I suggested by starting with round stock as the 2 main spigots will be central. |
