Simon Collier | 05/06/2022 21:31:19 |
![]() 525 forum posts 65 photos | My loco’s windows are 3D printed plastic with rebate for the glass, cut from large microscope slides 1 mm thick. Multiple specks of superglue have let go after a couple of months which is about what I expected. I considered silicone but it is stringy and I couldn’t apply small enough blobs. Any recommendations? |
not done it yet | 05/06/2022 21:48:58 |
7517 forum posts 20 photos | Hot glue gun? Contact adhesive? Re-make the windows with a couple of ledges, to at least reduce the held edges (to combat expansion/contraction? |
Ady1 | 06/06/2022 01:40:01 |
![]() 6137 forum posts 893 photos | pinkgrip |
Pero | 06/06/2022 04:14:51 |
193 forum posts | The glue used to stick rear vision mirrors onto windscreens may be your savior as it exactly fits your criterion of plastic onto glass. The only possible hiccup is the type of plastic in your 3D prints and whether the glue is compatible. Pero |
Michael Gilligan | 06/06/2022 06:10:31 |
![]() 23121 forum posts 1360 photos | In a similar vein to Pero’s suggestion … I would try using one of the LOCA UV-curing adhesives that are now so widely available. MichaelG. |
Simon Collier | 06/06/2022 06:34:51 |
![]() 525 forum posts 65 photos | Thanks for your suggestions. I had a look through my glue/sealant collection. The most promising is a clear contact type shoe glue. It doesn’t string too much so I should be able to apply some specs. I am reluctant to buy something special for about the 100 microlitres I need. I had never heard of pinkgrip nor have I ever used hot melt glue. |
Michael Gilligan | 06/06/2022 06:52:06 |
![]() 23121 forum posts 1360 photos | Posted by Simon Collier on 06/06/2022 06:34:51:
[…] I am reluctant to buy something special for about the 100 microlitres I need. . With respect, Simon … that does seem to make it rather pointless asking for recommendations. MichaelG. |
pgk pgk | 06/06/2022 07:46:13 |
2661 forum posts 294 photos | Posted by Michael Gilligan on 06/06/2022 06:52:06:
[…] I am reluctant to buy something special for about the 100 microlitres I need. . With respect, Simon … that does seem to make it rather pointless asking for recommendations. MichaelG. Indeed. How about using the silicone you avoided but masking off all the unwanted areas it may contaminate prior to application using a low tack tape? pgk |
Simon Collier | 06/06/2022 10:53:30 |
![]() 525 forum posts 65 photos | Slightly unfair, as ndiy suggested contact above, and having got it out and tested it, it is what I will try next. |
Michael Gilligan | 06/06/2022 13:56:59 |
![]() 23121 forum posts 1360 photos | Posted by Simon Collier on 06/06/2022 10:53:30:
Slightly unfair … . I will say no more on the matter then MichaelG. |
