Just Joined
Mike BackBurner24/05/2022 23:36:44
4 forum posts
47 photos
Hi All,
Looked at plenty of posts and thought it was time to take the plunge and join.
In the workshop: Warco WM240 Lathe and a WM 16B Mill.
I've had a very varied background and always had an interest in engineering but never really had the time or gear, now I have both and have begun to set my stall out.
My first build, which I started approx just over a year ago, was a Stuart S50 which I'm really pleased with.
Now in the deep end, I am just getting started on the Stuart Triple Expansion, it may never get finished but I'll give it my best and see how it goes. I'm hoping I can get some advice as required along the way and very much appreciate any help.
Thanks for taking the time to read this and I look forward to making some new friends along the way.
Cheers
Thor 🇳🇴25/05/2022 09:48:16
1766 forum posts
46 photos
Hi Mike,
Welcome to the forum. I assume many would be interested in some photos of your S50 and the Triple build. How to post photos here.
Thor
Edited By Thor 🇳🇴 on 25/05/2022 09:54:10
Jon Lawes25/05/2022 09:51:49
1078 forum posts
Nice to meet you Mike.
noel shelley25/05/2022 10:05:33
2308 forum posts
33 photos
Welcome to the forum, we're a fine body of men ! There are also some ladies. Noel
Mike BackBurner25/05/2022 12:56:17
4 forum posts
47 photos
Thanks for the warm welcome guys n gals and appreciate advice about uploading images Thor.
Stuart S50 Build
Stuart Triple Expansion Build
I’ve started the Triple build and just on fettling the base casting, have removed a fair bit from the outer edges but there’s still a fair bit to come out the centres.
If it’s allowed what’s the best way to go about setting up a build vlog on this site?
Thor 🇳🇴25/05/2022 14:10:02
1766 forum posts
46 photos
Hi Mike,
Your S50 looks very nice, well done.
Thor
Howard Lewis27/05/2022 18:55:20
7227 forum posts
21 photos
Welcome!
Looks like you are progressing well.
Keep it coming!
Mike BackBurner27/05/2022 20:18:49
4 forum posts
47 photos
Hi Howard,
Thank you and appreciate the interest.
So far so good, it's certainly been tricky so far mind. Quite a bit of excess material to remove which the mill was ideal for.
Now I've got a datum on the bottom of base it I intend to mount it on an ally block so as it's easier to hold in the vice to machine the top surfaces and prepare the crank slots.
I feel a bit more confident but would be a mistake to get too relaxed.
Cheers
Howard Lewis28/05/2022 09:29:18
7227 forum posts
21 photos
Hi MIke,
I find a set of parallels very useful to pack work in the vice, (Upwards and / or longitudinally ) for milling.
Mike BackBurner28/05/2022 09:40:12
4 forum posts
47 photos
Hi Howard,
Thanks, I do have and use parallels normally but for repeatable squaring I figured mounted to a block would facilitate this more readily.
The block may serve as a mounting base also, will see.
