Here is a list of all the postings Mike BackBurner has made in our forums. Click on a thread name to jump to the thread.
Thread: Just Joined |
28/05/2022 09:40:12 |
Hi Howard, Thanks, I do have and use parallels normally but for repeatable squaring I figured mounted to a block would facilitate this more readily. The block may serve as a mounting base also, will see. Mike |
27/05/2022 20:18:49 |
Hi Howard, Thank you and appreciate the interest. So far so good, it's certainly been tricky so far mind. Quite a bit of excess material to remove which the mill was ideal for. Now I've got a datum on the bottom of base it I intend to mount it on an ally block so as it's easier to hold in the vice to machine the top surfaces and prepare the crank slots. I feel a bit more confident but would be a mistake to get too relaxed. Cheers |
25/05/2022 12:56:17 |
Thanks for the warm welcome guys n gals and appreciate advice about uploading images Thor. I’ve started the Triple build and just on fettling the base casting, have removed a fair bit from the outer edges but there’s still a fair bit to come out the centres. If it’s allowed what’s the best way to go about setting up a build vlog on this site? |
24/05/2022 23:36:44 |
Hi All, Looked at plenty of posts and thought it was time to take the plunge and join. In the workshop: Warco WM240 Lathe and a WM 16B Mill. I've had a very varied background and always had an interest in engineering but never really had the time or gear, now I have both and have begun to set my stall out. My first build, which I started approx just over a year ago, was a Stuart S50 which I'm really pleased with. Now in the deep end, I am just getting started on the Stuart Triple Expansion, it may never get finished but I'll give it my best and see how it goes. I'm hoping I can get some advice as required along the way and very much appreciate any help. Thanks for taking the time to read this and I look forward to making some new friends along the way. Cheers Mike |
