c/out
AJAX | 27/04/2022 17:59:30 |
433 forum posts 42 photos | I have a single phase induction motor that I would like to put to use. The motor is wired with 6 leads. I have probed with a multimeter and found the following: White, red and yellow appear to be the motor winding connections (2, 4 and 9). The windings measure about 115R each. The two brown leads are connected together (about 1R6). They are electrically isolated from the other leads. I presume the two brown leads are connection 1 "c/out". Could anyone suggest how these two leads are used? I did wonder if it was "count out" but I've turned the motor over and the resistance does not change. Maybe a thermal trip? Many thanks, Brian
AJAX | 27/04/2022 18:01:35 |
433 forum posts 42 photos | Ignore me... I just realised that next to the 85 degrees it says "c/out". Must be thermal cut out. |
AJAX | 27/04/2022 18:02:42 |
433 forum posts 42 photos | Admin, please feel free to delete the thread! |
Michael Gilligan | 27/04/2022 18:41:42 |
![]() 23121 forum posts 1360 photos | With this pedigree, that should be a decent motor https://b-hepworth.co.uk/marine-wiper-systems/wynn-marine/ MichaelG.
noel shelley | 27/04/2022 21:41:20 |
2308 forum posts 33 photos | 1/22 Hp, not going to do much ? Noel |
AJAX | 27/04/2022 21:50:01 |
433 forum posts 42 photos | Posted by noel shelley on 27/04/2022 21:41:20:
1/22 Hp, not going to do much ? Noel It's a small geared motor. 50 lb-in torque. |
