JimmieS | 20/04/2022 09:34:08 |
310 forum posts 1 photos | I am rebuilding a 1960's BSA Bantam racer and would like to give an aged look, in keeping with the rest of the bike, to the new foot rests and brake pedal made from 6082T6. All thoughts would be very much appreciated.
Jim |
ega | 20/04/2022 10:19:08 |
2805 forum posts 219 photos | Walnut blasting? |
Hopper | 20/04/2022 10:21:36 |
![]() 7881 forum posts 397 photos | Salt water usually does a pretty good job of messing up alloy. Maybe boiling the parts there-in to speed up the process? Vinegar will probably etch into it too. Or caustic drain cleaner rubbed on with a rag and watched carefully? Bantam Racer? Classic. My first bike was a 150cc D3 Bantam with sprung heel. Snapped I don't know how many front axles jumping it over dirt mounds in the bush down the the back of home. Great little machine. And some of them were tuned up to do phenomenal speeds (Not mine though!), Got pics? |
Jouke van der Veen | 20/04/2022 11:09:17 |
203 forum posts 19 photos | Why destroying an alu surface by pickling? I woud give it a (dull) anodising coating. Or start with a light pickle and give it a anodising finish. |
MadMike | 20/04/2022 12:33:49 |
265 forum posts 4 photos | As a rebuilder and restorer of British bikes I see a case of over thinking this issue. The relevant parts are 6082T6 aluminium. You do not need to do anything at all. Simply make the parts and fit them. The aluminium will oxidise naturally and as a result will go dull and become a natural grey colour. Anodising is best discounted as that will provide an anodic surface to the aluminium which will retain its clean silver appearance for years. Other processes like blasting, rumbling etc will also create a non natural finish which will for a long time look like the cleaning process took place. If you want to speed up the process make the parts and simply leave them outside over winter, otherwise let nature take it course. |
Hopper | 20/04/2022 12:38:45 |
![]() 7881 forum posts 397 photos | Rubbing them down with Scotchbrite green pads will dull them down too, if that is all you want. |
JimmieS | 22/04/2022 19:22:19 |
310 forum posts 1 photos | Many thanks to all for your replies - much appreciated.
Jim |
Chris Evans 6 | 23/04/2022 08:22:00 |
![]() 2156 forum posts | Try a sample offcut in the dishwasher to see what it does to the finish. Maybe all you need ? |
Hacksaw | 23/04/2022 22:39:58 |
474 forum posts 202 photos | What would happen if it was placed in a poly bag filled with oxygen ? Would brass tarnish overnight ? |
Jouke van der Veen | 24/04/2022 13:11:15 |
203 forum posts 19 photos | This is about aluminium, not brass. Keeping it in 100% oxygen will not do much. Air is already 20% oxygen. You could also put the aluminium in boiling water which will make a dull surface. But clean it first thoroughly and do not touch it afterwards, otherwise you will get a “nice” stained surface from fingerprints etc. Try a test sample first. |
