Norfolk Boy | 19/04/2022 21:12:11 |
74 forum posts 18 photos | I have come across some lumps of 3" diameter swedish iron. I realise from google that it is fairly pure and has great magnetic properties if heated to a level I could not attain, and is used as sacrificial anodes and armatures etc. I was wondering if anyone has turned any and what it's usability in model engineering might be. Does it compare with any other metals for example. Is it too soft to be of value. Thanks Alan |
John Haine | 19/04/2022 22:03:16 |
5563 forum posts 322 photos | It's very soft and an absolute pig to mill in my experience. Only real application is for making magnetic polepieces. |
Nigel McBurney 1 | 20/04/2022 08:40:11 |
![]() 1101 forum posts 3 photos | I agree ,certainly not easy to machine very soft and stringy,I had experience of it as polepieces when converting electric typwriters into solenoid operated automatic typewriters,one solenoid for every key operated function. |
Martin Kyte | 20/04/2022 08:52:46 |
![]() 3445 forum posts 62 photos | I turned the cores for the solenoids on my Synchronome from Swedish Iron and they turned reasonably. As has been said it's a bit soft so I used HSS with a decent rake. We had some left over at work from our XRAY generator development. I would save it for making cores. regrds Martin |
Norfolk Boy | 20/04/2022 20:59:48 |
74 forum posts 18 photos | Thankyou for your replies gentlemen very helpful. Alan
John Olsen | 21/04/2022 11:12:07 |
1294 forum posts 108 photos 1 articles | The iron has its magnetic properties at ordinary temperatures. Where the high temperature bit comes in is that any iron will lose its magnetic properties at a high temperature. With soft iron like this, the permeability will drop at a high temperature, but it will regain it when cooled. With hard irons like permanent magnets, they will become demagnetised at a high temperature, and will remain demagnetised when they cool. The temperature this happens at is called the Curie temperature, and is the same temperature you want to attain for hardening things like silver steel, eg Cherry red, or more usefully, about the colour of a boiled carrot. This all happens because this is the temperature at which all the crystalline structure gets disrupted by the heat. It is not really a difficult temperature to reach, a propane torch will do it nicely. John |
