silly question about oil drip feeder ...
BASS 66611/04/2022 20:11:13
49 forum posts
38 photos
how often should an oil drip feed drip ? i was on the lathe yesterday for about two and a half hours and the feeders nearly emptied ..
was is the normal rate ?
another question .... what size should i turn a bar down to so as i can run a 3/8x24 die down it in mm ?
thanks guys ...
bernard towers11/04/2022 20:16:14
1221 forum posts
161 photos
9.54mm
Jon Lawes11/04/2022 20:45:18
1078 forum posts
I was told that with the myford oilers you should be just getting bored waiting for the next drip and then there it goes!
Mine tremendously over oil. I usually am on the lathe long enough in one go for the oilers to almost empty.
As for the thread cutting, there are charts which will help you out on google that you can print off for the workshop wall. Don't forget the material you are cutting will have a bearing on things too.
Hopper11/04/2022 22:13:17
7881 forum posts
397 photos
Two drops a minute. Uses about a quarter of an oiler-full in a day usually. Doesn't seem like much, until you come to clean up the mess in the tray -- and up the wall.
BASS 66612/04/2022 00:12:53
49 forum posts
38 photos
thanks guys ...
SillyOldDuffer12/04/2022 09:48:46
10668 forum posts
2415 photos
Better too much than too little!!!
AJW12/04/2022 21:09:52
388 forum posts
137 photos
I usually give 6 drips before I start then I'm not sure after that but they do drip!
Alan
Howard Lewis14/04/2022 10:35:42
7227 forum posts
21 photos
If you MUST turn to a Metric size to die a 3/8 UNF thread, rather than use 0.375" turn to 9.50 mm
Or that is what Zeus Charts show as the closest.
Howard Lewis14/04/2022 10:36:45
7227 forum posts
21 photos
