colin hamilton | 01/04/2022 08:47:54 |
186 forum posts 94 photos | So my mill is missing a few 'tightening levers' for locking the quill and the motor in place. They seem simple enough to make. Can you buy the small balls to go on the end? I was hoping for something around 20mm threaded to say m6. If anyone could point me in the right direction I would appreciate it. Cheers Colin |
Grindstone Cowboy | 01/04/2022 08:51:20 |
1160 forum posts 73 photos | Hi Colin Just had a search on Ebay for "plastic ball handles" and there's quite a choice available. Rob |
Nicholas Farr | 01/04/2022 08:53:00 |
![]() 3988 forum posts 1799 photos | Hi Colin, Balls Regards Nick. |
Pero | 01/04/2022 09:49:50 |
193 forum posts | I found quite an extensive range on Aliexpress. Various sizes available. Some with threaded brass inserts, some without. The ones I have are a hard plastic ( phenolic resin? ). The colour range is a bit limited, but OK if you like red or black. I'm not sure what size mill you have but you could find 20 mm a little small. 30 - 40 mm seem to be more common on machine tools. Hope this helps Pero |
David-Clark 1 | 01/04/2022 10:46:08 |
![]() 271 forum posts 5 photos | I used to buy from Radio spares for cross slide locks and tool post handles. Both round and tapered. |
colin hamilton | 01/04/2022 11:43:38 |
186 forum posts 94 photos | Thanks everyone. I've not got a wide choice of balls!! |
colin hamilton | 01/04/2022 11:44:23 |
186 forum posts 94 photos | Posted by Pero on 01/04/2022 09:49:50:
I found quite an extensive range on Aliexpress. Various sizes available. Some with threaded brass inserts, some without. The ones I have are a hard plastic ( phenolic resin? ). The colour range is a bit limited, but OK if you like red or black. I'm not sure what size mill you have but you could find 20 mm a little small. 30 - 40 mm seem to be more common on machine tools. Hope this helps Pero It's a bridgeport. Thanks for the advice |
Chris Evans 6 | 01/04/2022 12:07:57 |
![]() 2156 forum posts | Look at the WDS catalogue online. |
Howard Lewis | 01/04/2022 16:16:23 |
7227 forum posts 21 photos | Now that we know that is a Bridgeport, if the knobs are screw fit, rather than interference, the threads are unlikely to be Metric. Some of the Bridgeport owners on here should be able to tell you the dimensions. You will need to say which knobs are missing or damaged. Howard |
Grindstone Cowboy | 01/04/2022 16:46:51 |
1160 forum posts 73 photos | I think Colin is making the handles as well, so he can thread the ends to suit metric balls if needed. Rob |
Grizzly bear | 01/04/2022 18:25:49 |
337 forum posts 8 photos |
New Myford Pack Of 10 Machine Balls / Knobs Threaded 3/16" Whitworth BSW Thread | eBay
10 Solid Forged Mild Steel Metal Solid Fabrication Balls Spheres Gates 10mm-70mm | eBay The first pack of the Solid Forged Mild Steel Metal Solid Fabrication Balls were very smooth, my second order they were quite rough. Good luck........... |
old mart | 01/04/2022 18:33:32 |
4655 forum posts 304 photos | Here are some more in stainless steel: |
