Pantograph Plasma Shape Cutting Machine
Bill Kunz30/03/2022 19:19:04
6 forum posts
I fabricated this pantograph shape plasma cutting machine for duplicating steel brackets and other hardware. A variable speed magnetic knurled rotor moves around an overhead mounted template. The plasma torch tip, directly below, duplicates the shape in steel up to the thickness capacity of your plasma cutter. Shapes that would fit in a 16 inch circle, and straight lines up to 36" can be cut.
The frame of the machine is constructed of aluminum extrusions from the 8020 Company. The rest was fabricated from square tubing and cold roll steel bar. A model railroad transformer and small gear motor provide variable speeds in forward and reverse. Magnetic tracing rotor consists of a rare search magnet sitting atop a rotary burr.
Small holes can be drilled after parts are cut out.
Pantograph1
Pantograph2
Sample shapes
Ady131/03/2022 23:55:15
6137 forum posts
893 photos
Looks like a very capable setup
Are you going to do a construction article?
Hopper01/04/2022 00:03:21
7881 forum posts
397 photos
That is really ingenious. And equally well executed. Nice job!
Jeff Dayman01/04/2022 00:14:12
2356 forum posts
47 photos
Smart, and nicely made! well done.
Michael Gilligan01/04/2022 06:43:20
23121 forum posts
1360 photos
Good thinking, and neat execution yes
More details [ whether here or in MEW ] would be appreciated.
Bill Kunz08/05/2022 15:11:09
6 forum posts
Posted by Ady1 on 31/03/2022 23:55:15:
A pdf file containing construction plans can be found here: Pantograph machine plans
Michael Gilligan08/05/2022 18:05:44
23121 forum posts
1360 photos
Thanks for that, Bill yes
