Member postings for Bill Kunz
Here is a list of all the postings Bill Kunz has made in our forums. Click on a thread name to jump to the thread.
Thread: Easy power tailstock feed for your lathe
09/05/2022 13:16:38
Posted by ega on 09/05/2022 10:47:43:
Nice to see vintage (black and white) photos of a vintage lathe!
Here's another:
South Bend Model 9A
09/05/2022 02:14:27
Many years ago I came up with a simple power feed arrangement for the tailstock on my 9" South Bend lathe when drilling, reaming, tapping, etc.
I got a two piece clamping shaft collar with an ID the same size as my tailstock spindle. Then I made a forked bracket that engaged the shaft collar as shown in the photo. Bingo, I had a power tailstock feed. Just slightly loosen the tailstock clamp and let the carriage pull it along at the desired feed rate.
Power tailstock feed 3
Power tailstock feed 1
Edited By Bill Kunz on 09/05/2022 02:15:18
Thread: Small (9cm x 9cm) home-made CNC plasma table
08/05/2022 19:00:59
Some examples of pieces I've cut with the little machine:
Brough Superior
Vincent Black Shadow
Matchless 500
08/05/2022 15:29:49
I built this small CNC plasma table, which is located just outside my basement door under my deck. I keep the unit protected by a fire pit cover when not in use.
The stepper motors remain on the machine, and the cables can be connected in a couple of minutes. The air compressor, plasma cutter, and computer are inside the door. The electronics and software are from FlashcutCNC.
This arrangement eliminates the problem of plasma dust and smoke, and possible fire hazards. More details about the physical table can be found at the link below. Some of the components, particularly the linear rails, are more readily available in the U.K. than in the U.S.
Details about CNC plasma table build
CNC plasma table
Compressor & plasma cutter
Fire pit cover
Edited By Bill Kunz on 08/05/2022 15:32:47
Edited By Bill Kunz on 08/05/2022 15:34:24
Thread: Pantograph Plasma Shape Cutting Machine
08/05/2022 15:11:09
Posted by Ady1 on 31/03/2022 23:55:15:
Looks like a very capable setup
Are you going to do a construction article?
A pdf file containing construction plans can be found here: Pantograph machine plans
30/03/2022 19:19:04
I fabricated this pantograph shape plasma cutting machine for duplicating steel brackets and other hardware. A variable speed magnetic knurled rotor moves around an overhead mounted template. The plasma torch tip, directly below, duplicates the shape in steel up to the thickness capacity of your plasma cutter. Shapes that would fit in a 16 inch circle, and straight lines up to 36" can be cut.
The frame of the machine is constructed of aluminum extrusions from the 8020 Company. The rest was fabricated from square tubing and cold roll steel bar. A model railroad transformer and small gear motor provide variable speeds in forward and reverse. Magnetic tracing rotor consists of a rare search magnet sitting atop a rotary burr.
Small holes can be drilled after parts are cut out.
Pantograph1
Pantograph2
Sample shapes
