Motor mounting details
colin hamilton28/03/2022 21:40:45
186 forum posts
94 photos
20220328_172938.jpgSo the motor on my milling machine table feed is dead. I've got another motor but the fittings are different. I intend to make a plate which will interface between the mill and the motor. I presume the motor mount will be to a standard which I can reference to get the dimensions? Can anyone help point me in the right direction? Cheers 20220328_172739.jpg
Chris Gunn28/03/2022 21:47:05
459 forum posts
28 photos
Colin, Look for Brook Crompton Motors and have a look at their catalogue, which lists all current specs, or ABB will probably show the dims in their catalogue, you motor plate should show the frame size you have, I cannot make it out from the picture.
Chris Gunn
John Haine28/03/2022 22:31:48
5563 forum posts
322 photos
Is the motor really dead, or has the capacitor (if single phase) gone, or some other fault? Induction motors themselves almost never "die" uness it emitted a lot of loud brown smelly smoke.
Martin Connelly29/03/2022 01:03:53
2549 forum posts
235 photos
The motor plate shows Y and Δ voltages so there will be no capacitor.
Martin C
AJAX29/03/2022 07:27:52
433 forum posts
42 photos
Photo is not clear but I think it may state IEC71 frame size. Google the full code and you'll find tables showing the standard dimensions.
mgnbuk29/03/2022 10:14:16
1394 forum posts
103 photos
Metric motor flange dimensions
Above link gives dimesnisons of standard metric motor mounting flanges.
Nigel B.
colin hamilton29/03/2022 10:23:57
186 forum posts
94 photos
Posted by John Haine on 28/03/2022 22:31:48:
It really is dead because I killed it trying to rewire it to delta!!
colin hamilton29/03/2022 10:32:04
186 forum posts
94 photos
Posted by mgnbuk on 29/03/2022 10:14:16:
Nigel B.
Super useful-thanks
not done it yet29/03/2022 13:47:37
7517 forum posts
20 photos
Posted by colin hamilton on 29/03/2022 10:23:57:
Get a motor repair shop to fix your mistake(s)? What happened? Is it really dead or just connected up wrongly?
For an interface plate, it is not the bolt holes that are particularly important - it is the spigots that actually centre the motor/plate to the machine.
mgnbuk29/03/2022 16:03:43
1394 forum posts
103 photos
If the "mistake" is the same one I made trying to do the same thing on a similar size motor (415V only 3 phase FB2 clone spindle motor), then the "fix" is a rewind !
The winding wire is very fine on this size motor and, despite being careful, trying to dig out and separate the star point one of the wires broke off flush where it vanished into the varnished winding - rather "game over" at that point.
I had it rewound rather than replace it as IIRC there is something non-standard about the FB2 motor - undersize shaft maybe.
Nigel B.
Howard Lewis29/03/2022 16:56:33
7227 forum posts
21 photos
Sod's Law says that the replacement motor bolt holes will partially coincide with the existing tappings!
This will necessitate re orienting the new motor, if possible, to separate the motor fixing holes in the adaptor plate, from the csk holes fixing it to the machine.
It might be, as already suggested, better to get the existing motor rewound, (partially of fully ) so that coils are wired in delta!
colin hamilton29/03/2022 20:31:24
186 forum posts
94 photos
When I was digging out the star point the wires just all gave way and broke down. I'm actually looking forward to trying to repurpose the other motor. I did have a quick word with a motor rewind shop and it's going to be too expensive. If it all goes wrong I'll get one of those unit's that sort of hang off the leadscrew.
