Myford ML7 1956 ... Question on drive belt and Stalling when cutting
Ian Montana06/03/2022 16:15:31
15 forum posts
Hi
I am the new owner of an ML 7 standard lathe from 1955 to 1956
Got the lathe home yesterday and assembled it today. A few teathing problems but generally ok
Clutch wasnt engaging properly but that was solved through adjustment
The drive belt to the chuck is similar to a fenner zero downtome belt in appearance but black and it doesnt have the twist connectors
Ive tensioned this belt but it still can be stalled quite easily. Doesnt seem to ve contaminated with oil or anything
It means that only very small cuts can be taken of say 5 tho at a time
Is this normal for this size of lathe ... looks a pain to change the belt unless i use another jointed belt
Any thoughts would be appreciated
Monty
Andrew Johnston06/03/2022 16:24:02
7061 forum posts
719 photos
It's not normal, should be capable of much bigger depth of cut. Stalled means the motor slowed and then stopped. Is that what happens, or was the belt slipping instead?
Simon Williams 306/03/2022 16:27:05
728 forum posts
90 photos
What's stalling? Does the motor keep turning but the countershaft stops, or is it that the spindle pulley keeps running but loses its drive to the spindle. If it's this last there is a drive dog in the bull wheel (the gear behind the chuck) which must be engaged. Has it slipped out of the drive position - perhaps to use the back gear.
You really need a copy of the user manual.
5 thou a time for the best you can do is definitely wrong.
Ian Montana06/03/2022 17:52:03
15 forum posts
Its the belt driving the chuck that slips
Its tensioned coreectly .... the motor keeps running fine
Amyone recommend the best belt to replace this with ?
Martin of Wick06/03/2022 18:17:13
258 forum posts
11 photos
1 With the belt de-coupled, does the spindle revolve freely when chuck spun by hand. If not, find out why before proceeding.
2 check for any obvious oil contamination and clean.
3 If you have, as I think, a link style belt, bear in mind the tension may often need to be much higher than for a normal A section V belt, and the cheaper the replica belt the higher the tension required, usually.
4 Replace dodgy belt with standard or segmented A section belt for little cost, or if you have to, get a genuine Fenner product replacement. You should then be good to go with 40 thou cuts (if you want to be brutal).
BTW a suitable basic 23 inch A section V belt should cost about a fiver plus delivery from any number of  bearing, drive, belt, motion  factors  on the net.
Edited By Martin of Wick on 06/03/2022 18:28:37
Ian Montana06/03/2022 18:23:27
15 forum posts
ill replace it with an endless belt and go from there i think
Thanks for responding good advice 👍
Cheers
Ian
John Haine06/03/2022 18:24:58
5563 forum posts
322 photos
The black link belts commonly available from a certain supplier are completely useless and you will never get them to work because the plastic is slippery. As Martin says, get a Fenner of the correct size, RS have them, and fit it quite tight, and note that it has a right and wrong way of going on. IIRC, the links are formed so one end is sort of an arrow head in shape and that should point in the direction in which the tension from the driving pulley is being applied. So the belt should be fitted so that the points on the lower part of the belt as you look at the h/s assembly point towards the countershaft.
noel shelley06/03/2022 18:25:24
2308 forum posts
33 photos
The belt you need is an A 23/A620. On an ML7 it is easy to change ! The belt to the motor is A34.5 inside length. I would NOT recommend a link belt. Good luck. Noel.
Edited By noel shelley on 06/03/2022 18:27:40
Ian Montana06/03/2022 18:28:32
15 forum posts
Thanks John and Noel
Good to get support from the community
Ian
Martin Kyte06/03/2022 18:41:34
3445 forum posts
62 photos
You have got the belt the right way round have you?
regards Martin
Ian Montana06/03/2022 19:04:53
15 forum posts
Hi Martin
ive cut the belt off and ordered a fenner endless replacement
it was the right way round just a cheap imitation of the fenner zero,down time belt
thanks for responding
John Olsen06/03/2022 19:08:07
1294 forum posts
108 photos
I found that the standard V belt was heating up the spindle pulley, to the point that the bush inside would come loose. Apart from securing the bush better with loctite, I made a new set of pulleys for it that use a poly V belt, which does not heat the pulleys. As a bonus, I was able to squeeze in an extra step and widen the range of ratios slightly, because poly V will drive satisfactorily around a smaller diameter. Hemingway does a set for using Poly V on the Super 7, but not for the ML7.
Grizzly bear06/03/2022 21:32:01
337 forum posts
8 photos
@ Ian Montana,
I like that name. (Big country/State).
If it's not been mentioned, are the belt pulleys secure on their respective shafts, really secure.
Good luck.............
Hopper07/03/2022 09:18:11
7881 forum posts
397 photos
My 1957 ML7 will happily take 100 thou deep cuts with carbide insert tooling all day long, and more with a well honed HSS toolbit.
Sounds like the slippery plastic link belt is your problem. But while you are at it, check the condition of your pulleys. The V grooves can wear to a sort of round profile and let the belt slip. The smallest diameter V groove on the headstock spindle pulley wears the most for some reason. I had to replace mine as it slipped in the highest speed when taking heavy cuts.
Also, a common problem on the ML7 is the cheapo diecast headstock spindle pulley coming loose on the bronze bush/gear that is pressed into the middle of it. Cure is to pull it apart and reassemble with Loctite and maybe a grub screw.
And of course make sure the drive dog for the back gear is firmly in place on the bull gear and the allen head screw holding it is well tight.
The Myford Users Manual PDF is widely available for download on the net for free. Well worth getting. As is L H Sparey's book The Amateur's Lathe andalso  Ian Bradley's Myford Series 7 lathe manual. All still in print, cheap as chips and invaluable.
Edited By Hopper on 07/03/2022 09:21:22
Ian Montana07/03/2022 09:36:57
15 forum posts
Thanks Hopper - I'll check when I fit the new belt
Any idea where the PDF is located that you mention
Thanks
Hopper07/03/2022 09:46:29
7881 forum posts
397 photos
Posted by Ian Montana on 07/03/2022 09:36:57:
Thanks
Ubiquitous. I found mine by googling Myford ML7 Users Manual.
