An Mich Kotzelbaum | 25/02/2022 16:29:18 |
9 forum posts | Hi all, for some of you this question will be trivial. I would like to build a mechanism that i'd like to implement in a sort of "mono tone musical instrument" for my nephew. Basically: i have a tuning fork mounted on a support and it should be hit by a hammer (or a stick..) by pushing a button. Now, the button should be "soft" to push, on the other hand the hit should be powerful enough to produce a loud tone. I first thought at the classic boxing bell mechanism. It's fine, but it seems a bit hard to use. Now i'm actually thinking at clock mechanisms. In this case there is a spiral spring that stores the energy. The idea of charging the whole thing by a knob or handle seems fun to me. Maybe it could provide for more than one hit Does anybody know if there is already some mechanism like this, out there? If not, any ideas at all? Thank you in advance for your feedback!
An Mich |
Michael Gilligan | 25/02/2022 20:30:03 |
![]() 23121 forum posts 1360 photos | You might find inspiration here : **LINK** http://507movements.com … It’s fun to browse, anyway. MichaelG. |
pgk pgk | 25/02/2022 20:35:34 |
2661 forum posts 294 photos | A trigger release, such as found on crossbows - suggest a captive bolt wound or drawn back by hand. Similarly, could use the basis of an airgun cocking and trigger mechanism or for simplicity a simple hanging rod & weight that snaps into a release mechanism with a pull-string to reload. The problem with the above options is that the clapper will likely rest against the tuning fork and dampen it although with the pendulum version it could be arranged not to swing back far enough for a second strike. pgk |
old mart | 25/02/2022 20:48:26 |
4655 forum posts 304 photos | How about the mechanism design similar to the bass drum pedal in a drum kit. |
Martin Connelly | 26/02/2022 08:08:33 |
![]() 2549 forum posts 235 photos | Two tone door bells do this. Martin C |
An Mich Kotzelbaum | 26/02/2022 08:19:59 |
9 forum posts | Posted by Michael Gilligan on 25/02/2022 20:30:03:
that's so cool!! Thank you, it is fun to watch indeed and instructive as well
An Mich Kotzelbaum | 26/02/2022 08:28:11 |
9 forum posts | Posted by pgk pgk on 25/02/2022 20:35:34:
A trigger release, such as found on crossbows - suggest a captive bolt wound or drawn back by hand. Similarly, could use the basis of an airgun cocking and trigger mechanism or for simplicity a simple hanging rod & weight that snaps into a release mechanism with a pull-string to reload. The problem with the above options is that the clapper will likely rest against the tuning fork and dampen it although with the pendulum version it could be arranged not to swing back far enough for a second strike. pgk I thought of rossbows and airgun mechanisms as well, but beside the clapper issue you mentioned i'm under the impression that it would be a bit hard to load the spring. Maybe i'm wrong though. Could you please explain the solenoid option? I'm afraid i don't understand what you mean Thank you ! |
An Mich Kotzelbaum | 26/02/2022 08:32:06 |
9 forum posts | Posted by old mart on 25/02/2022 20:48:26:
How about the mechanism design similar to the bass drum pedal in a drum kit. I thought about it, piano mechanics as well. Would definitely work, but most of users (children!) would push the "pedal" so that the hammer would dampen the tuning fork... |
An Mich Kotzelbaum | 26/02/2022 08:36:32 |
9 forum posts | Posted by Martin Connelly on 26/02/2022 08:08:33:
Two tone door bells do this. Martin C Right! Thank you.. Too bad i can't use electricity Maybe i can implement the plunger mechanism into the design though.. |
pgk pgk | 26/02/2022 08:51:43 |
2661 forum posts 294 photos | Posted by An Mich Kotzelbaum on 26/02/2022 08:28:11:
I thought of rossbows and airgun mechanisms as well, but beside the clapper issue you mentioned i'm under the impression that it would be a bit hard to load the spring. Maybe i'm wrong though. Could you please explain the solenoid option? I'm afraid i don't understand what you mean Thank you ! You don't need a very strong spring or this purpose and any re-loading can be done with mechanical advantage - long lever or winding drum. pgk |
An Mich Kotzelbaum | 26/02/2022 10:02:24 |
9 forum posts | I got your point. I must experiment a little with loaded spring mechanisms to get a feeling, i guess. I also like the idea of the finger in the gap, it would require a battery of course.. I don't feel confident enough with electromagnetism but it may be the simplest option. Thanks again
An Mich |
Circlip | 26/02/2022 11:08:34 |
1723 forum posts | Never seen the hammer chime on a Mantle clock??????? Regards Ian. |
An Mich Kotzelbaum | 26/02/2022 11:29:41 |
9 forum posts | Posted by Circlip on 26/02/2022 11:08:34:
Never seen the hammer chime on a Mantle clock??????? Regards Ian. No, actually But it is definitely the concept i'm trying to break down and simplify for my purpose
thanks! |
pgk pgk | 26/02/2022 11:35:18 |
2661 forum posts 294 photos | One of the simplest mechanisms that comes to mind would be an upward angled tube with an end cap with hole... rod with knob goes through there and compression spring with washer inside the tube. A loose ball bearing is shot along the tube when you pull back on the knob and let go, That hits tuning fork (or hits something that hits tuning fork) but cannot escape the tube end gap and returns by gravity. pgk |
Martin Kyte | 26/02/2022 13:24:21 |
![]() 3445 forum posts 62 photos | A simple hammer on a semi flexible rod mounted vertically from a horizontal rod pivoted t both ends. The horizontal rod carries a counterbalance on 2 right angled levers to bias the hammer against a stop just shy of the tuning fork. A short tail on the pivioted rod to act as the activating lever/key. The action is such that pressing the activating lever lifts the hammer away from the stop and on release allows it to fall back. The flexibility of the hammer rod allows a small over run such that the hammer hits the tuning fork. Adjustment is by counter weight choice and adjustment of the stop. regards Martin
SillyOldDuffer | 26/02/2022 14:11:01 |
10668 forum posts 2415 photos | Something like this maybe: When the cam is turned it pushes the spring arm away from the tuning fork until the apex of the cam is passed. Then the arm springs back and dings the clapper into the tuning fork. Simplest arrangement is with a straight spring arm but a rigid arm could be hinged and powered with a coil spring, opposing super-magnets, or an elastic band. Devil as always is in the detail:
Meccano is quite good for testing experimental set-ups. Dave |
Jeff Dayman | 26/02/2022 14:34:17 |
2356 forum posts 47 photos | I'd suggest the same idea/mechanism as used in a Sten gun, adapted to "fire" vertically. Basically it is a fairly heavy steel rod running vertically inside a loose fit tube. There is a spring below the rod causing it to jump up and hit the fork when triggered. After impact the rod falls back down by gravity, and if the spring is adjusted just so, it resets the rod behind the trigger catch / sear, and re-compresses the spring for the next actuation. Again, weight of rod and strength of spring have to be adjusted just so to get the rod mass vs the spring force to work as described. A nut soldered or welded on the bottom end of the vertical tube, with an adjuster screw installed inside, would provide a simple length/force adjustment for the spring, to " dial it in ". The trigger could be made with a button on a release lever, or left as a plain lever. It also needs to have a light spring and a stop to allow automatic resetting with minimal force. Just food for thought. As with all simple mechanisms gravity is your friend. |
An Mich Kotzelbaum | 27/02/2022 07:44:05 |
9 forum posts | Wow, so many inputs. Thank you all! I like all your ideas, i already started to make some prototypes, thanks God it's sunday
Jeff Dayman | 28/02/2022 14:33:59 |
2356 forum posts 47 photos | Be sure to post some photos of your progress An Mich, would love to see how this works out. Cheers! |
An Mich Kotzelbaum | 28/02/2022 19:08:02 |
9 forum posts | I surely will! I started to assemble something like SillyOldDuffer suggested, but i must find a thicker spring arm. Yes, it's all a matter of experimenting different things by now, i never dealt with springs in a qualitative way, it's a good project to get a feeling about it!
Thanks again to all of you! |
