I need help to identify shaper
panjic alojz21/02/2022 12:35:44
5 forum posts
18 photos
Does anyone know what brand of this shaper is he came with this table.
Ady121/02/2022 13:21:24
6137 forum posts
893 photos
There's a list of shaper types here
panjic alojz22/02/2022 04:54:21
5 forum posts
18 photos
I looked at the list but didn't find shaper
bernard towers22/02/2022 07:38:02
1221 forum posts
161 photos
The list says shapers,spotters etc. it’s down the right hand side on my iPad page
Clive Foster22/02/2022 09:19:47
3630 forum posts
128 photos
The screw adjuster at the back of the ram to help accurately set the stroke endpoint is unusual and may well be a unique refinement on such a small shaper.
Klopp and Heinmann had similar adjusters on some of their large machines but they always cast the name onto the machine. As far as i'm aware they didn't make shapers that small either.
Alan Johnson 722/02/2022 09:30:16
127 forum posts
19 photos
The essential dimension of a shaper is the maximum length of the stroke. This dimension is missing!
panjic alojz22/02/2022 09:33:27
5 forum posts
18 photos
bernard towers I check Shapers, Slotters, Borers & Vertical La from Adept shapers to Wickman (re-badged Klopp) I can not find my shaper.
panjic alojz22/02/2022 09:57:17
5 forum posts
18 photos
I took more pictures
Ady122/02/2022 10:31:15
6137 forum posts
893 photos
As mentioned you have an offset ram position adjuster, so find this, and you have your answer
The front slide gib adjustment nuts are HUGE if they are originals
Edited By Ady1 on 22/02/2022 10:49:45
RobCox22/02/2022 10:43:33
82 forum posts
44 photos
From the shape of the guards, the position of the clutch lever and the stroke length indicator, it looks like it's either an Atlas shaper or a clone of one.
Ady122/02/2022 11:06:42
6137 forum posts
893 photos
The side controls say royal/viceroy to me... but that ram adjustment has to be designed from the ground up to fit into the bullwheel mechanism
Ady122/02/2022 11:46:07
6137 forum posts
893 photos
It's not offset... it was the picture..
Hopper22/02/2022 12:02:39
7881 forum posts
397 photos
What country is the shaper in? And are the nuts and bolts etc in metric or imperial?
panjic alojz22/02/2022 12:20:28
5 forum posts
18 photos
I checked the list of shapers again and only Atlas and Heinemann have ram position adjuster behind of machine
I am from Europe, I checked nuts and bolts are in metric
The height adjustment of the table is in front of machine
I always have something weird that I can't figure out what it is
Edited By panjic alojz on 22/02/2022 12:23:20
Bazyle22/02/2022 13:04:47
6956 forum posts
229 photos
Well your name seems Polish so assuming you are thereabouts it is likely an eastern block copy or adaptation of a better documented make. Perhaps reaching out to German and Polish forums will be more forthcoming.
