Myford Super 7 Crossfeed Endplate
Any ideas where i can get one?
Michael Fothergill17/01/2022 16:35:56
5 forum posts
I have a Super 7 lathe and a very long time ago the end-plate was repaired using a brash plate. Its not a bad repair actually bit it gives ever so slight movement when machining.
Although there are a number of endplates online i can't find one for a super 7 (powerfeed model)
Does anyone know where you can get these items? Seem like an item that's easily damaged so you'd think there was plenty of people making replacements!
PS if anyone is interested in the lathe im selling it shortly along with a variety of tools, chucks etc
DiogenesII17/01/2022 19:25:50
859 forum posts
268 photos
Er, Myford Ltd?
Myford Ltd. - End Plate for Cross Slide (Power Feed)
John Haine17/01/2022 20:13:09
5563 forum posts
322 photos
What's a brash plate?
Grindstone Cowboy17/01/2022 20:44:25
1160 forum posts
73 photos
Brash? It's a yellow metal used by Sean Connery, I think.
Rob
Steviegtr18/01/2022 02:37:06
2668 forum posts
352 photos
What sort of damage are you meaning. Mine had side bore wear. But not sure what your damage is.
Steve.
P>S a pic would help.
Michael Fothergill04/02/2022 09:37:48
5 forum posts
Thanks for that DiogenesII but unfortunately that doesn't fit my machine, That's the connoisseur model, mines an SK. I've been trying Myford for over a year but as luck would have it they have just got a handful in that fits mine and its coming today. Also found Metric cross slide assembly Myford super 7 dial handle plate screw and nut | eBay and have since found this will fit.
And correct, Sean Connery did fix the machine before me and his typing skills and drink problem were nearly as bad as mine!
Steviegtr it cracked the casing, scrap but i was clutching at straws trying to fix.
Appreciate all your replies.
Neil Lickfold04/02/2022 11:02:04
1025 forum posts
204 photos
Thanks Michael, I just ordered a complete spare cross slide assembly for mine. Just 4 screws and then I can change out from the 2mm pitch metric assembly, to the home made 0.5mm pitch assembly now. The one I made, uses the imperial 100 thou dial, so each division matches 0.01mm diameter on a metric micrometer. Lots more winding of the handle of course, but makes it so much easier if you are making a lot of bits that you need to be as close as possible.
Cheers, and thanks again for the parts in stock heads up.
Michael Fothergill04/02/2022 11:18:41
5 forum posts
Marvelous! You are welcome! £47 for the end plate, £125 for the full assembly! if i'd known the full assy was a straight fit before i ordered the plate, common sense would have prevailed.
What a simple joy it is to maintain these machines after working on European cars/vans/pushchairs.......
Michael Fothergill04/02/2022 11:22:02
5 forum posts
PS I also spoke to Frans at Myfordsolutions in Netherlands, that guy looks switched on and also holds stock of some hard to get items and its not as expensive as you'd think to get them here
ega04/02/2022 11:56:02
2805 forum posts
219 photos
Michael Fothergill:
Joking aside, would you please explain about the "brash plate"?
There is another thread on this forum containing the phrase (unknown to the OED) but it left me none the wiser.
I'm glad you were able to solve your problem; it's good to know spares are still available.
SillyOldDuffer04/02/2022 12:31:43
10668 forum posts
2415 photos
Posted by ega on 04/02/2022 11:56:02:
Impossible to answer without joking, but it's a typo for 'brass plate'
Sean Connery's famous Scottish lisp is a source of humour throughout the English speaking world. Examples:
  • What time does Sean Connery go to Wimbledon? About tennish.
  • What did Sean Connery say when a book fell on his head? "I have only my shelf to blame."
Only funny because the confusions are ridiculous. Sean Connery was a star.
Michael Fothergill04/02/2022 14:18:18
5 forum posts
I really don't know what to say only laugh Dave. Sean Connery certainly was a star!
Enjoy!
ega04/02/2022 14:29:19
2805 forum posts
219 photos
Not the most obvious typo for brass! I speculated that brash plate was a variation on fish plate.
The belated photo makes it clear - thanks.
Neil Lickfold11/02/2022 05:04:06
1025 forum posts
204 photos
My Assembly arrived today. Sadly it was missing the spring washer or diaphragm washer for the tension on the dial. Anyway, what I really noticed was the pain to get to the 4BA screws holding the nut to the carriage. I found some 4BA set screws 5/8 long with a 1/16 hex in them. Made some nut heads from 1/4 hex brass and glued with 620 loctite. These are much easier for my fingers to access than the long series screw driver. I have a long series 1/16 allen key and is easy to install and a 1/4 spanner to just nip up. This is for using my fine thread assembly that is 1mm/ rev on diameter.
Tony Pratt 111/02/2022 08:30:17
2319 forum posts
13 photos
I have always assembled the nut to the carriage first, then add the restwink
Tony
