Andrew Cressey | 24/12/2021 08:45:53 |
59 forum posts 12 photos | Hi everyone i have been putting this off for a long time as i know little about electronics.I have decided to convert my small mill to belt drive with the use of a treadmill motor.I have purchased this power board my potentiometer has three blue wires from what i understand they are wiper hi-lo but it all so has two black wires but i cannot figure out where they go.I believe they are to power the machine up as that is what happened when it was used originally.I all so have a E-stop button with 4 connectors on the back any help would be great. **LINK**asoft_starters/dc_drives/high_voltage_(%3E_50v)/open_framez_reversing/gsd5-240-10c
Andrew Cressey | 24/12/2021 08:48:14 |
59 forum posts 12 photos | That link doesn't work sorry i will try again |
Andrew Cressey | 24/12/2021 08:48:44 |
59 forum posts 12 photos | https://www.automationdirect.com/adc/shopping/catalog/drives_-a-_soft_starters/dc_drives/high_voltage_(%3E_50v)/open_frame_-z-_reversing/gsd5-240-10c |
Michael Gilligan | 24/12/2021 09:48:05 |
![]() 23121 forum posts 1360 photos | For convenient reference: **LINK** https://www.automationdirect.com/adc/shopping/catalog/drives_-a-_soft_starters/dc_drives/high_voltage_(%3E_50v)/open_frame_-z-_reversing/gsd5-240-10c . Now … a photo of your potentiometer would be useful, Andrew MichaelG. |
Andrew Cressey | 24/12/2021 10:12:04 |
59 forum posts 12 photos | |
Andrew Cressey | 24/12/2021 10:15:25 |
59 forum posts 12 photos | I all so have this potentiometer as well |
Andrew Cressey | 24/12/2021 10:15:41 |
Michael Gilligan | 24/12/2021 10:28:36 |
![]() 23121 forum posts 1360 photos | Thanks, Andrew I would assume that the two black wires are connected to a built-in switch … a few seconds with a multimeter should confirm. MichaelG. . Edit: __ or a look here: Edited By Michael Gilligan on 24/12/2021 10:32:39 |
Andrew Cressey | 24/12/2021 10:42:42 |
59 forum posts 12 photos | I agree because the potentiometer has a click sound when rotated but where do these wires go ? |
Robert Atkinson 2 | 24/12/2021 10:54:39 |
![]() 1891 forum posts 37 photos | Hi Robert G8RPI. |
Andrew Cressey | 24/12/2021 11:05:17 |
59 forum posts 12 photos | Thanks Robert can you tell me what goes onto the four connectors on the stop button could i use that as the power button |
noel shelley | 24/12/2021 11:09:46 |
2308 forum posts 33 photos | As per Michaels comment. The 3 tags on the paxolin together will be the pot the other 2 will be an on/off switch. Noel. |
Andrew Cressey | 24/12/2021 11:11:51 |
59 forum posts 12 photos | Thanks Noel i get it now but dont know what to do with the four connectors on the stop button
Michael Gilligan | 24/12/2021 11:15:16 |
![]() 23121 forum posts 1360 photos | Andrew, Did you spot this PDF lurking at the bottom of the page that you referenced ? **LINK** : https://cdn.automationdirect.com/static/specs/gsd5dcdrives.pdf MichaelG. |
Andrew Cressey | 24/12/2021 11:18:10 |
59 forum posts 12 photos | Excellent is the DPST switch the switch i am referring to with the four connectors and does it matter which goes where as my switch does not have any symbols saying what's what |
Andrew Cressey | 24/12/2021 12:54:39 |
59 forum posts 12 photos | I see now i will need a separate on/off switch as well as the stop button |
Andrew Cressey | 24/12/2021 13:12:34 |
59 forum posts 12 photos | What about this one https://www.screwfix.com/p/eaton-red-green-flush-push-button-start-stop-station-no-nc/249hf |
Michael Gilligan | 24/12/2021 18:00:21 |
![]() 23121 forum posts 1360 photos | Posted by Andrew Cressey on 24/12/2021 11:18:10:
Excellent is the DPST switch the switch i am referring to with the four connectors and does it matter which goes where as my switch does not have any symbols saying what's what . The switch in your photo appears to be of ‘open construction’ … so it shouldn’t take long to determine its connections. DPST = Double Pole Single Throw MichaelG. . If you're unfamiliar with the terminology … this should help: **LINK** https://www.arrow.com/en/research-and-events/articles/understand-the-fundamentals-of-switch-poles-and-throws |
