V.Tunç Burak | 14/12/2021 10:50:05 |
![]() 2 forum posts | Hi, I came across your forum while researching about Myford. I am an industrial product designer. I have a workshop on product design, model and prototype in Istanbul/Turkey. When I first opened my business, I had a 1959 model myford tri-leva. In time, I completely disassembled the lathe, repaired it and painted it. I made some additions to the pedestal it is on. I designed and produced a lighting product suitable for its design. The only thing missing is the tailstock for the completion of my lathe. I could not find the original tailstock in Turkey. I couldn't get it from other countries either. As a prototype workshop, I am capable of creating a model of the tailstock. I want to make a 3d drawing of the tailstock, produce it on a 3d printer, and have it cast with a sand mold. To do what I say; i need technical drawing or 3d model file of original tailstock. I would be glad if you help me in this regard. I am sharing the photos of my lathe with you. Thanks for your help. V.Tunç Burak Bronze Design Modeling Prototype instagram : bronzemodelleme https://files.fm/u/zydkzm6pa
Brian H | 14/12/2021 13:14:31 |
![]() 2312 forum posts 112 photos | I don't know if this helps; https://www.ebay.co.uk/itm/393668757108?hash=item5ba87c8674:g:VHEAAOSwWGBhgVE- All the best with your lathe. Brian |
peak4 | 14/12/2021 13:21:32 |
![]() 2207 forum posts 210 photos | Hello and welcome, I can't help with a formal drawing unfortunately. |
Howard Lewis | 14/12/2021 18:21:54 |
7227 forum posts 21 photos | Welcome! Tri Leva is not a Myford model type, but a means of changing speed, by using different pulley combination to effect a speed change, rather than doing so by moving the drive belt manually. Consequently, we do not know if your machine is a ML7 or a later version. You would ,do well to find the Serial Number, and the more expert on here may well be able to tell the model and when it was manufactured.. You might then be able to find a Tailstock if you post an ad in "Wanted"c on here, in M E W , or try Google. You might find at a machine tool dealer, or on one of the auction sites. They might even be glad to get rid of a loose item like that! You need to specify which model it is, and to be safe, look ay the various places, Myford manual, or dealer's pictures to see the correct pattern to suit your machine. The ML 7 Tailstock is not the same as the later models . The centre height will be the same, nominally, but the exact pattern and operation may well differ. Hope that this is pf some help Howard
Grizzly bear | 14/12/2021 19:15:43 |
337 forum posts 8 photos | Welcome, Good luck with your search. Howard Lewis (Above) ***** Myford Ltd Home Page (British Engineering at its best) ML7 Myford Ltd Home Page (British Engineering at its best) Super 7 Myford Tailstock for sale in UK | View 43 bargains (for-sale.co.uk)
Bear.......... |
T.B | 14/12/2021 20:58:04 |
54 forum posts 21 photos | Looking at the photos , its a Myford ML7 Tri leva It also looks like a long bed version to me and that would explain the Super 7 type cross and top slide which are far superior and where often fitted to long bed ML7's Any Myford 7 series tailstock will fit as the bed dimesions are the same on all models , in fact the Super 7 type tailstock was often fitted to long bed ML7's along with the different top and cross slides as mentioned above so its very likely the missing tailstock was a Super 7 type |
V8Eng | 14/12/2021 21:25:25 |
1826 forum posts 1 photos | I think the Tri-leva attachment could only be fitted to an ML7 lathe. |
duncan webster | 14/12/2021 21:31:39 |
5307 forum posts 83 photos | There are several ML7/S7 tailstocks on ebay, prices £150 upwards. Getting postage to Turkey is probably an issue, but you could contact sellers and see what happens |
Howard Lewis | 14/12/2021 22:53:08 |
7227 forum posts 21 photos | A Tailstock, admittedly, used, can be bought either from a machine tool dealer or on E bay, so it would take less time to unpack, fit and align than to print a patterns, and machine the casting and other components.. . Howard Edited By Howard Lewis on 14/12/2021 22:57:27 |
V.Tunç Burak | 17/12/2021 09:24:12 |
