Dave S | 09/12/2021 18:25:00 |
433 forum posts 95 photos | After a bit of a gap, and a workshop re arrange I have my little CNC in a place where I can get to it, and will probably want to use it. This is my plan to actually make use of it. I am usign Fusion360 for the CAD/CAM - I know the personal use thing is restictive, btu Ive tried and I just cant get on with FreeCAD at the moment. I need to learn so many things that adding a new CAD interface is one thing to many. Anyway, ramble over: I am trying to understand how to model the clamps/ vice / other things that I need to have around the stock, but do not want to bump into with the cutter. I think I model them as extra bodies in the positions they will be, but shoudl they be components? Any tips gratefully received. Dave Edited By Dave S on 09/12/2021 18:25:13 |
JasonB | 09/12/2021 18:34:31 |
![]() 25215 forum posts 3105 photos 1 articles | For the amount of CNC work that I do I don't bother with fixturing, just bear in mind how I will hold a part when doing the cam to make sure nothing gets hit. I've not found personal use that restrictive, I just play about with stay down distance and percentage and also the non engaged feed rate and that goes a long way for compensation for the loss of rapids, plus I try to use a decent feed rate which it defaults to as the rapid rate. |
Geoffrey Mowatt | 09/12/2021 18:47:01 |
9 forum posts | I am strictly an F360 amateur but have played with adding fixtures and also tabs and follow along with Lars Christenson on YouTube as I find his instruction very useful. Bear in mind that you can select sections of your parts' profiles for milling etc so that you avoid some areas, these could be where you have your clamps etc located. Adding fixtures is useful in the simulate function as then you can see when any collisions might occur. I looked at paying for Fusion but decided against for some of the same reasons as JasonB, I edit the G code by hand looking for obvious places where the rapids can go and replacing with faster feeds there. As an aside I've just started looking at G wizard free trial and it has made lots of sense for me with my very small and quite flexible Boxzy 3d router - well worth a look if you have a few spare hours. No connection with any of the companies etc. Good luck, Geoff |
An Other | 09/12/2021 20:49:24 |
327 forum posts 1 photos | I confess to being a beginner with CNC - but re the above posts about editing the Gcode files - I ran into a similar problem (odd 'boxes' appearing in the Gcode) and had to edit the sequences which cut these boxes out. I use Linux, and tools like Candle2 or UGS have a 'visualization' of the Gcode showing tool paths which allow fairly easy analysis of what is going on, but they usually require the machine to be connected and/or running. There is also a tool called 'Camotics' which is primarily intended to drive a proprietary CNC machine, but it will allow visualization without being connected to the machine. It will run under Linux or Windows. No connection with any of the above software, except as a user |
Emgee | 09/12/2021 22:38:43 |
2610 forum posts 312 photos | Dave If you set your Work Co-ordinate System (WCS) on the workpiece either centre or corner of the part if milling around the outside surfaces when workholding in the vice you only need to make sure -Z max keeps the tool clear of the vice or fixture. If you set the Safe height for the tool to be clear of the top of the work and any clamps you should be able to move anywhere in the working envelope without fear of crashes. If turning same applies to the chuck jaws, just make sure you always set the -Z to be ahead of the jaws when external turning, I use the front face for the WCS on the lathe. At least you can run the operation within the program to check for any problems. Emgee Edited By Emgee on 09/12/2021 22:53:25 |
JasonB | 10/12/2021 07:47:11 |
![]() 25215 forum posts 3105 photos 1 articles | I do it more or less as Emgee says which for our often one off jobs is fine. I feel modelling all the vices, clamps and fixtures is more of use to commercial users where they may have several parts on the table at once to save having to keep stopping and starting and reduce tool changing times, even more so when using 3+2 or 5 axis where you do need to be even more carful as the trunnion swings about. Emgee mentions safe height, yes you could probably save a few seconds by not having the tool lift so far above the work and only lifting higher to clear a fixture but would it entail the same or more work modeling the positions of the clamps etc and then making sure you actually use them on the machine in the position you have modelled them? Unlikely for a one off but for production runs of several 100 parts then yes it's probably worth the effort as time is money. You will also need to model the tool holder and set stickout from holder for each tool to make full use as it's not going to work if the machine keeps the cutter clear but drives the tool holder into a clamp or stud If I've got cap head screws holding the work down then I will stick with F360 default 10mmclearance and 5mm retract height, if it's in the vice then drop it down to say 8mm and 4mm and just make sure there is more material sticking up above the vice than my work top height to lowest bottom height For sheet work then I just make sure any clamps may will be outside the simulated part or set the tool ctr to only just go beyond the bounary of the work and use tabs or screws if there are hole sin the part to stop it moving once the outside is cut. |
