David Noble | 06/11/2021 14:56:54 |
![]() 402 forum posts 37 photos | I’m having difficulty drilling a lantern pinion. The 0.030” diameter drill does have a tendency to wander. David |
speelwerk | 06/11/2021 16:00:14 |
464 forum posts 2 photos | You can break most of the twist off and regrind what is left. Niko. |
John Haine | 06/11/2021 16:36:09 |
5563 forum posts 322 photos | What is the provenance of the drill? I have a couple of those "microboxes" and one of them when you look at the drills many of the points are very poorly centred. |
Jeff Dayman | 06/11/2021 17:08:05 |
2356 forum posts 47 photos | any chance given the style of lantern pinion you are trying to make to do all the drilling on two plates soldered together as a stack, then separate them and cut them to final round shape? I've used this method many times when trying to make plates or discs with identical hole locations. I usually drill an extra smaller dia hole to act as a reference for aligning the finished assy and get the holes assy'd in the same order they were drilled. For the drilling itself, I'm assuming you used a centredrill first, and are using good quality twist drills? |
David Noble | 06/11/2021 17:08:14 |
![]() 402 forum posts 37 photos | Posted by speelwerk on 06/11/2021 16:00:14:
You can break most of the twist off and regrind what is left. Niko. Thanks Niko but I don't think that I'm up to sharpening a drill that small. Having said that, I could give it a go. David
David Noble | 06/11/2021 17:09:51 |
![]() 402 forum posts 37 photos | Posted by John Haine on 06/11/2021 16:36:09:
What is the provenance of the drill? I have a couple of those "microboxes" and one of them when you look at the drills many of the points are very poorly centred. Thanks John, I'll check them. David |
David Noble | 06/11/2021 17:13:35 |
![]() 402 forum posts 37 photos | Posted by Jeff Dayman on 06/11/2021 17:08:05:
any chance given the style of lantern pinion you are trying to make to do all the drilling on two plates soldered together as a stack, then separate them and cut them to final round shape? For the drilling itself, I'm assuming you used a centre drill first, and are using good quality twist drills? Thanks Jeff, I've not tried that but it's certainly worth a shot. I did attempt a centre drill and also a spot drill but the indentation left by them was larger than the hole I am drilling so the benefit of a centre drill was lost. David |
Martin Kyte | 06/11/2021 17:21:00 |
![]() 3445 forum posts 62 photos | Drills that small can be held in the drill chuck almost to their end. You only need 2 or 3 mm protruding. This makes the drill very stiff and it will not whip. I don't know how you are drilling. I do mine by dividing the lathe headstock with the pinion blank in the chuck/collet and the drill in an auxilliary spindle on the cross slide running as fast as I can get it. It is also possible to get very small centre drills if you really get stuck. They go down to 00 which have a 25 though pilot. regards Martin |
Peter Cook 6 | 06/11/2021 17:36:11 |
462 forum posts 113 photos | There is an interesting You Tube video that I tripped over a few days ago that shows the making of a lantern pinion. He makes a spade drill from the pivot wire to drill the trunions. DIY Cycloidal Gear Cutter: Part 4 Making the Lantern Pinion - YouTube Might be an idea - the spade drill is probably a lot stiffer than a twist drill at that size
speelwerk | 06/11/2021 17:41:43 |
464 forum posts 2 photos | Posted by David Noble on 06/11/2021 17:08:14:
You can break most of the twist off and regrind what is left. Niko. Thanks Niko but I don't think that I'm up to sharpening a drill that small. Having said that, I could give it a go. David That small I sharpen them out of hand on a flat grinding stone, it takes a little practise but works. Niko.
Edited By speelwerk on 06/11/2021 17:44:07 |
Dave S | 06/11/2021 18:09:10 |
433 forum posts 95 photos | Spade drill is the way to go for that sort of size. PCB drills are another option that works well edit to add photo, Lego man for scale: Dave Edited By Dave S on 06/11/2021 18:13:29 |
Andrew Johnston | 06/11/2021 18:25:08 |
![]() 7061 forum posts 719 photos | I concur with some of the above. Use quality drills, and carbide drills are stiffer. Make sure that the setup is rigid and that the work is firmly clamped. For small drills spotting with a centre drill first is a waste of time; they leave a poorly defined indent that invites the following drill to wander. I find that letting the drill just "touch" the surface before applying cutting pressure allows the drill to form its own dimple. Here are two 0.8mm holes drilled 8mm deep in tungsten alloy, on the Bridgeport, using the above techniques: Andrew |
Martin Kyte | 06/11/2021 18:50:42 |
![]() 3445 forum posts 62 photos | I agree with you Andrew on the comment on spotting with a centre drill but the OP wants a 30 though hole and 00 centre drill have a 25 though pilot so it's perfectly possible to obtain aa accurate pilot hole with the correct tiny lead for following up with the 30 thou drill. regards Martin |
David Noble | 06/11/2021 19:12:04 |
![]() 402 forum posts 37 photos | Thank you all, I'm happy that it's not only my incompetence that's the problem There are some great ideas here for me to try. Thanks again, David |
Andrew Johnston | 06/11/2021 20:50:49 |
![]() 7061 forum posts 719 photos | Posted by Martin Kyte on 06/11/2021 18:50:42:
........00 centre drill have a 25 though pilot........ My experience of small centre drills is that you look at them, and ping the pilot snaps. Andrew |
Martin Kyte | 07/11/2021 08:20:17 |
![]() 3445 forum posts 62 photos | Posted by Andrew Johnston on 06/11/2021 20:50:49:
........00 centre drill have a 25 pilot........ My experience of small centre drills is that you look at them, and ping the pilot snaps. Andrew Well you are more geared to to the heavier end of the spectrum Martin Edited By Martin Kyte on 07/11/2021 08:20:57 |
David Noble | 07/11/2021 10:32:27 |
![]() 402 forum posts 37 photos | Posted by Peter Cook 6 on 06/11/2021 17:36:11:
Thanks for the link Peter, I noticed that he drilled the first side of the pinion with a twist drill and then carried on through the other side with a spade drill. What would this be for? David |
Peter Cook 6 | 07/11/2021 11:10:43 |
462 forum posts 113 photos | Posted by David Noble on 07/11/2021 10:32:27
I noticed that he drilled the first side of the pinion with a twist drill and then carried on through the other side with a spade drill. What would this be for? If I understand him correctly ( at about 4:40-4:50 in) he drills the first side undersize with the carbide drill, and then uses the spade drill - which is made from the same pivot wire as will be used for the trundles - as a reamer for the front holes to get them to exact size. Then he uses those holes to support and control the shaft of the spade drill while he makes the rear holes. His carbide drill doesn't look long enough to drill all the way to the back in any case. It just looked like a neat and fairly simple way of getting the holes to exactly the size of the pivot wire. |
Graham Butcher | 07/11/2021 11:59:32 |
21 forum posts 3 photos | Another tip when making lantern pinions. When making the bobbin, leave a thin section in the middle so that this will act as a guide for the drill as it bridges the gap. After all the holes are drilled this section can be removed. |
David Noble | 07/11/2021 12:08:48 |
![]() 402 forum posts 37 photos | Thanks Peter, that makes sense. David |
