What's it for
The Real Ron Skingley | 10/09/2021 09:14:23 |
46 forum posts 2 photos | Hello All, Discovered I have a quick-change tool post. |
Gavlar | 10/09/2021 13:03:37 |
119 forum posts 1 photos | It's for a pin that locates in the compound slide, presumably to prevent the toolpost moving under load. |
Paul Lousick | 10/09/2021 13:10:36 |
2276 forum posts 801 photos | "It's for a pin that locates in the compound slide, presumably to prevent the toolpost moving under load" Or possibly to lock it in a square position and not rotated. |
Mike Hurley | 10/09/2021 13:22:43 |
530 forum posts 89 photos | Posted by Gavlar on 10/09/2021 13:03:37:
It's for a pin that locates in the compound slide, presumably to prevent the toolpost moving under load. I've got exactly the same model ( RDG? ) and it doesn't align with the corresponding detent hole in my compound. To be fair, I think it is sold as ' for Myford and similar size machines ' maybe it does align on Myfords specifically? ( Mine's not a Myford ) I have always thought it might be an alignment hole for a pin when manufacturing?
The Real Ron Skingley | 10/09/2021 13:27:59 |
46 forum posts 2 photos | Thanks chaps.
The Real Ron Skingley | 10/09/2021 13:30:50 |
46 forum posts 2 photos | Posted by Mike Hurley on 10/09/2021 13:22:43:
Ah yes, could well be a manufacturing alignment hole. |
Mike Hurley | 10/09/2021 13:35:40 |
530 forum posts 89 photos | Co-incidence or what. The non myford lathe that I've got is an ageing BV20! So I have exactly the same issue. Never come across anyone with one of these before - is yours the version with the gearbox for speed changing or the belts version? If the gearbox one I assume you also own a pair of substantial ear defenders? Mike |
The Real Ron Skingley | 10/09/2021 13:36:12 |
46 forum posts 2 photos | Just as a general comment, in case anyone's wondering. |
The Real Ron Skingley | 10/09/2021 13:38:28 |
46 forum posts 2 photos | Ha ha, yes Mike it's the geared version. |
The Real Ron Skingley | 10/09/2021 13:40:24 |
46 forum posts 2 photos | The lack of a faceplate is causing real problems trying to machine the Victoria flywheel. But that's another story. |
Mike Hurley | 10/09/2021 13:46:11 |
530 forum posts 89 photos | What area are you from? If local ish you can borrow on of my faceplates no problem ( i'm in the West Midlands ) regards |
The Real Ron Skingley | 10/09/2021 13:48:52 |
46 forum posts 2 photos | Thanks for the offer Mike, but I'm in SW Ireland. |
Michael Gilligan | 10/09/2021 13:49:56 |
![]() 23121 forum posts 1360 photos | On the original Dickson tool-posts, a hole was intended for an alignment pin. The purpose of any ‘similar’ hole on a ‘clone’ is still open to question. MichaelG. . Ref: http://www.lathes.co.uk/latheparts/page13.html Edit: __ as a slight digression: The patent for a tool-setting fixture is worth a look: https://worldwide.espacenet.com/patent/search?q=pn%3DGB1215583A Edited By Michael Gilligan on 10/09/2021 13:57:27 |
The Real Ron Skingley | 10/09/2021 13:55:00 |
46 forum posts 2 photos | Ah yes, thanks. The Dickson one has the pin square-on which would make sense. |
John Haine | 10/09/2021 14:02:53 |
5563 forum posts 322 photos | Yes it's for a locking pin, and no there isn't normally a hole drilled for it on the topslide since lathe and toolpost are from separate suppliers. You have to drill your own hole in your topslide to fit.. I gave up using the topslide on my Myford as it's tool flimsy and tapers are done with the CNC. I made a block to fit the cross slide to support the QCTP and drilled it for a dowel pin as I want to get precise re-registration of tools when removed/replaced - without a pin the TP will move if even a tiny bit, for example when parting.
The Real Ron Skingley | 10/09/2021 14:07:28 |
46 forum posts 2 photos | That's a good idea. |
The Real Ron Skingley | 10/09/2021 14:56:27 |
46 forum posts 2 photos | Posted by Michael Gilligan on 10/09/2021 13:49:56:
On the original Dickson tool-posts, a hole was intended for an alignment pin. The purpose of any ‘similar’ hole on a ‘clone’ is still open to question. MichaelG. . Ref: **LINK** Edit: __ as a slight digression: The patent for a tool-setting fixture is worth a look: Edited By Michael Gilligan on 10/09/2021 13:57:27 Patent makes interesting reading. |
Mike Hurley | 10/09/2021 15:44:06 |
530 forum posts 89 photos | Thanks Michael & John for clarifying things - the info on Lathes.co was particularly useful! I'll look into getting a suitable locking fitting knocked up as I have had a few toolpost ' slippage ' issues in the past! regards Mike |
The Real Ron Skingley | 10/09/2021 15:51:42 |
46 forum posts 2 photos | Yes, thanks all. |
JasonB | 10/09/2021 16:03:11 |
![]() 25215 forum posts 3105 photos 1 articles | Victoria flywheel should be OK held with a 4 jaw gripping inside the rim. I hardly ever use a faceplate for turning flywheels finding the 4-jaw much better. |
