For hot air engine
steamdave | 29/08/2021 16:47:12 |
526 forum posts 45 photos | Q1. Q2. Dave
pgk pgk | 29/08/2021 16:59:12 |
2661 forum posts 294 photos | You can get thin sheets of material to line/insulate the access port in wood burner flues which should be flexible enough to use a few layers. It would take experimentation with wood burner rope glue to see if it'd stick it? pgk |
noel shelley | 29/08/2021 17:06:48 |
2308 forum posts 33 photos | American K 23 is a furnace and kiln lining ! It is in brick form but very soft so can be cut by knife of saw. making an inner liner of this material and fixing in place with air setting cement would work for where the flame hits and then the rest could be lined in ceramic fibre, possibly beefed up with rigidizer to keep its shape. 1/4" is not thick enough to keep much heat in, but for this application I assume the flame will be small. Good luck Noel. |
John P | 29/08/2021 19:46:38 |
451 forum posts 268 photos | Just follow the instructions on the drawing that you have shown , the lining |
steamdave | 29/08/2021 21:05:28 |
526 forum posts 45 photos | I believe the main reason for the lining is not so much to retain any heat, but to prevent the paint coating getting damaged by the heat. With the (hopefully) small flame, there should not be as much heat as from my gas torch and maybe the Kaowool in greater thickness will be adequate for the second engine (steel firebox, about 3" diameter). John P. What did you use for the lining in your firebox? Engine is the Improved Rider, 2" bore from Myers. Dave
JasonB | 30/08/2021 06:55:06 |
![]() 25215 forum posts 3105 photos 1 articles | In that case Dave why not just use a stove paint, that is what I have used on my Robinson and Heinrici and CHUK without problems as well as quite a few IC engine exhausts. Thermacure is the one I like |
John P | 30/08/2021 10:02:21 |
451 forum posts 268 photos | Hi Dave The engine that was made was also a Myers it was 3inch i think, The engine was in model engineer from June 2013 4459 to The photo gives no idea of scale it is about 24 inches to the top of the chimney. |
steamdave | 30/08/2021 12:06:14 |
526 forum posts 45 photos | Very nice looking engine there, John. Dave |
steamdave | 30/08/2021 14:11:48 |
526 forum posts 45 photos | Posted by JasonB on 30/08/2021 06:55:06:
In that case Dave why not just use a stove paint, that is what I have used on my Robinson and Heinrici and CHUK without problems as well as quite a few IC engine exhausts. Thermacure is the one I like I might just do that. Dave |
John P | 30/08/2021 17:44:40 |
The lining is there to insulate the firebox from the rest of the engine, John |
