Student switchgear
Student switchgear
bernard towers28/08/2021 14:52:06
1221 forum posts
161 photos
fb2d74b2-413d-492e-88d8-cc860621c008.jpegHelp, anyone know where to get replacement switchgear like this?. The lid on the box says Craig and Derricot type CLS. UT
Emgee28/08/2021 16:00:07
2610 forum posts
312 photos
Hi Bernard
Is that the fwd/rev switch operated by an apron lever ?
Emgee
bernard towers28/08/2021 22:16:13
1221 forum posts
161 photos
No it’s the off/on operated by the large lever
Chris Crew29/08/2021 01:20:00
418 forum posts
15 photos
Could you tell us what the problem is with it, please? It' looks such a simple and accessible mechanism that it may be repairable if a direct replacement is not available.
BTW, Craig and Derricot are still in business, although yet another British company that has been taken over by a foreign concern, but can be found at https://craigandderricott.co.uk/  They may be able to help with either a direct replacement or an equivalent component.
Edited By Chris Crew on 29/08/2021 01:24:46
bernard towers29/08/2021 07:48:18
1221 forum posts
161 photos
The contacts are burnt out so badly that the overcenter eye on one side of the switch has disappeared, this held one end of of the spring that makes the switch operate quickly. The spring is hanging down off the leg that is not as badly damaged. There are one or two of their switches on our favourite auction site although different shape and size, maybe the internals are the same and switch could be rebuilt in its old casing. Have now found contact details thankyou and will be ringing them Tuesday so job will have to sit in the chuck for a week or so.
DC31k29/08/2021 08:32:45
1186 forum posts
11 photos
Is it, or has it been converted to single phase? The wiring in the box is somewhat non-standard (Colchester did not use plastic chocolate blocks).
You may be able to use the mechanical parts of the switch to operate a microswitch (even maybe a reed switch) that controls a relay/contactor to switch the power.
With an external device to do the switching, you only need one pole of the switch in your photo to be functional: the contactor it controls will switch two or three poles if required.
The mechanical action occurs from the top, with the plunger moving up and down. Weld or glue or sellotape something like one of these under the plunger: https://www.switchelectronics.co.uk/push-button-plunger-limit-switch-spdt-16a
bernard towers29/08/2021 13:23:25
1221 forum posts
161 photos
Yes was 3 phase about 30 years ago it’s an ex university machine. Was converted to single phase for me so it’s not done too badly.
bernard towers02/09/2021 16:58:27
1221 forum posts
161 photos
Craig and derricot washed their hands of me said they didn’t make it any more sorry(that overused word again) and didn’t offer an alternative either or a company likely to help. Found Bernstein’s on the net very helpful with a suggestion and would be better to buy it from an agent, which was local. This is when it goes bad ,ring them with part no say they will ring back but don’t, ring the next day same thing 3rd day I visit them and ask how things are going and why no return calls and they mumble about minimum order costs, so I suggested that was my decision to make. Left them with a flea in the ear and ordered and paid for it from the manufacturers in 15 mins. Will post more when arrives and it is fitted, cross fingers.
larry phelan 102/09/2021 17:40:57
1346 forum posts
15 photos
Sad to say, Bernard, that kind of response seems to be quite common these days.
Hope you get sorted out OK, could be a nice machine when you get it running.
bernard towers12/09/2021 20:01:07
1221 forum posts
161 photos
Just an update lathe operational again just got to tidy wiring and refit tinware and gear cover and we are good to go.The switch came from Bernstein if any body else needs to do the same job. It is a bit different but just needs a 3mm mounting plate and adjustments to the spacer thickness so not too difficult in the end.
bernard towers12/09/2021 20:04:16
1221 forum posts
161 photos
DC31k12/09/2021 22:13:59
1186 forum posts
11 photos
Are you using it to switch the motor directly or via a contactor?
If is is switching direct, please consider what follows:-
The spec. for the switch here:
https://www.wolfautomation.com/limit-switch-plunger-snap-action-1nc-1no/
Datasheet here:
https://www.galco.com/techdoc/bnst/608.7352.002_dat.pdf
says it is rated for 10A, so that would be about 3HP at 230v single phase.
For a Student-sized lathe, that rating looks to me to be a little low.
bernard towers12/09/2021 22:58:27
1221 forum posts
161 photos
No it’s via a contractor in the front plate
