it was supposed to be 7/15 bsf
brian jones 11 | 25/06/2021 12:32:47 |
347 forum posts 62 photos | My ML7 came wit a rotating 4 tool holder designed to take a 5/16 sq hss tool piece, I decided I wanted to revert to the simple tool clamp which can take 1/2" shank and so removed the 4 pce block. I found the original handle didnt have a thru thread so have to find a nut (or pay ca £5 for a Myford long nut. Well I was really puzzled when I couldnt get the std nut to fit, I even dug out a 7/16 die nut to chase the thread - which started chewing thread - funny had the correct od? so stop - think???? light bulb moment, I checked my thread table and found it was a 7/12 UNF 20tpi vs 18 tpi for bsf - wasted an hour on this anyone else come across this anomally - was it part of the 4 pce tool block attachment? thats my guess
KWIL | 25/06/2021 13:53:38 |
3681 forum posts 70 photos | The original toolpost stud must have been changed before you acquired the lathe. My M7 has its original stud and I have a 4 way block which uses it. The Myford Quick Change block is also Ok on it. |
brian jones 11 | 25/06/2021 14:01:36 |
347 forum posts 62 photos | Indeed I was fooled by this for a while. I have taken to sourcing a car wheel nut which doubles as a long thread nut. 7/16 unf is a common size for small cars. I was also caught out by this unf/bsf switch when restoring an old ransomes mower, I didnt expect a switch for some of the chassis parts mixing different thread tables in your workshop is a nightmare. I have taken to spraying trays with different colours so perhaps they dont get confused.
btw how do i get to post pictures on here? i cant see how to create an album? |
peak4 | 25/06/2021 14:06:43 |
![]() 2207 forum posts 210 photos | Posted by brian jones 11 on 25/06/2021 14:01:36:
................. btw how do i get to post pictures on here? i cant see how to create an album? Hello and welcome to the madhouse; some of us are madder than others. |
Richard S2 | 25/06/2021 14:49:41 |
![]() 237 forum posts 135 photos | I replaced the tool post stud on my 1949 ML7 way back in 1986 with a new one from Myford, purely to accompany a new Single tool holder clamp set. The original one is clean (BSF) threaded. I presume the threads on yours are a bit chewed now?, So IF you wish to go down the 'back to original' path and use the proper nut, drop me a PM. The old one is used as a 'Keeper' for the Single parts set as a whole for storage, but I'm sure I can find an alternative. |
brian jones 11 | 25/06/2021 14:57:41 |
347 forum posts 62 photos | Well its a little bit chewed as i stopped when saw what was happening. here is the car nut i bought for £1.20, chromes a bit flash harry but so am I |
