Higgins1994 | 19/06/2021 17:06:31 |
25 forum posts | hi, im in the midst of making a leadscrew clutch for my ML10and have come to drilling it through but unfortunatly i am in a sticky situation in terms of available drills haha. ive got it drilled to 15.90 but the nearest drill up from that that i have is 16.20 :/ has anyone here made one and can tell me if i will get away with that or will it be too loose on the leadscrew? the plain section of mine measures at 15.87 so assuming itll be a bit much cheers |
JohnF | 21/06/2021 10:21:14 |
![]() 1243 forum posts 202 photos | Hi, I think you need to revert to imperial sizes and my guess is the ML10 leadscrew is 5/8" 0.625 inches so best to azure a 5/8? reamer ! John PS where are yo located ? nothing on your profile ! |
not done it yet | 21/06/2021 10:29:53 |
7517 forum posts 20 photos | Best plan is to try it - drills don’t always cut to their precise size It’s why reamers are preferred. 15.87mm is, indeed, exactly 5/8”. What sort of fit are you requiring? Likely already too big if needing a shrink fit. |
Graham Meek | 21/06/2021 10:50:03 |
714 forum posts 414 photos | From my days of owning a Myford ML10 this hole needs to be either bored or reamed 5/8" or 15.87mm, (15.90mm is top limit on a H7 hole). The finish left by a drill will hardly be good enough. There is also an Oilite bush present in the original Myford assembly for the threaded part of the leadscrew to rotate in. Remember the clutch continues to rotate when the leadscrew is disengaged, or stationary. Without the clutch the normal leadscrew rotates in two Oilite bushed pressed into the Bed. Thus the free end of the leadscrew needs some sort of bearing to support it, as the clutch body rotates. Steel on Mild steel is not a good mix without plenty of lubrication. Regards Gray, |
JOHN HORLER | 22/06/2021 11:47:18 |
5 forum posts | You will need to bore out the the housing to accept an oilite bush which myfords sell at a reasonable price, O/d is 3/4" ,bore 5/8", length 1-1/4", if the Bush is not fitted you will wear the leadscrew in no time. Hope this helps Regards John |
duncan webster | 22/06/2021 12:37:04 |
5307 forum posts 83 photos | Oilite bushes have a slightly oversize bore as supplied, when you press them in to the correct size hole the bush bore finishes up at correct size. I'd make a plug gauge, measuring small holes accurately isn't easy. |
JOHN HORLER | 22/06/2021 12:48:58 |
5 forum posts | Also don't forget to soak the oilite bearing in oil for 24hours before fitting |
