Here is a list of all the postings JOHN HORLER has made in our forums. Click on a thread name to jump to the thread.
Thread: ML10 leadscrew clutch ID? |
22/06/2021 12:48:58 |
Also don't forget to soak the oilite bearing in oil for 24hours before fitting |
22/06/2021 11:47:18 |
You will need to bore out the the housing to accept an oilite bush which myfords sell at a reasonable price, O/d is 3/4" ,bore 5/8", length 1-1/4", if the Bush is not fitted you will wear the leadscrew in no time. Hope this helps Regards John |
Thread: Centap cutting oil |
05/06/2021 23:12:51 |
Do you get any staining on slides etc when using the oil? Cheers John |
Thread: Cheap machine & equipment cover |
04/06/2021 18:30:40 |
That's interesting thought cotton sheets would hold moisture & where the fabric touches any metal would that not cause rust? I use a kind of plastic sheet covering my ml10 & it causes no problems but then I do keep all exposed metal surfaces well oiled. All my tools are kept in sealed plastic boxes to keep the tin worm away,bit of a pain I know but it's the only way if you have a damp shed, |
