Robert Butler | 13/06/2021 18:30:25 |
511 forum posts 6 photos | Gentlemen I am hoping the knowledgeable forum members can throw some light or confirm my suspicions please. My Super 7 PX was purchased as a Metric Machine and I decided to convert it to Imperial purchasing the feed screws and micrometre dials from Myford. I didn't get round to fitting them for some considerable time but when I did I had a cyclical issue with the screw or nut. It was impossible to set the backlash satisfactorily. The nut supplied was made from streel as the original. I refitted the metric screw and nut and it was possible to adjust the backlash to less than one micrometre division and the screw and slide were as near to perfect as one has any right to expect. I tried the imperial screw again and the variable backlash problem resurfaced. I contacted Myford who to their credit after checking the screw and agreeing there was a defect gave a fair discount toward a replacement. The new nut was of a bronze? material. The screw and nut operate smoothly before assembly, but when assembling the nut, screw and PX pinion the action becomes extremely stiff. Tried refitting the metric screw, perfect! I contacted Myford again who provided fitting instructions which closely mirrored the method I had been using. "Fasten the nut and collared gear on to the screw and then fasten that onto the saddle, screw the nut all the way in before attaching the cross slide to the mounting bracket, put the two screws for the bracket in loosely and then as you're winding the whole unit out with the loose screws then tighten as this aids self aligning. Sometimes also the apron will need slackening off as this allows for the collared gear to mesh with the apron." I am reluctant to slacken the apron, as it will then need tightening and I would think I will be back to square one! Given the metric screw and nut align and can be adjusted to perfection and the only issue with the first imperial screw and nut was the periodic backlash error it appears there is a problem with the new bronze not and screw. My view is either the bronze nut is not concentric with the screw or apron. This is not a New Myford bashing exercise! Any thoughts or suggestions would be very much appreciated. Robert Butler
Edited By Robert Butler on 13/06/2021 18:34:05 Edited By Robert Butler on 13/06/2021 18:36:19 Edited By Robert Butler on 13/06/2021 18:38:32 Edited By Robert Butler on 13/06/2021 18:51:54 |
John P | 13/06/2021 19:52:02 |
451 forum posts 268 photos | Hi Robert, You could try and the new lead screw and nut without the power cross feed gear in place and see if you can adjust the new screw backlash and see if it will work satisfactorily . The old metric screw is presumably 2 mm pitch and .500 inch diameter the same od as the new 10 tpi imperial screw , the part about " but when I did I had a cyclical issue with the screw or nut. " seems to suggest some problem with the internal key in the drive slot in the leadscrew. Perhaps you will try this and let us know how you get on.
John |
speelwerk | 13/06/2021 20:07:14 |
464 forum posts 2 photos | I probably misunderstand the English "you're winding the whole unit out" but after tightening the nut I wind the whole unit in as far as possible and then tighten the bracket screws. Niko. |
Trevor Drabble | 13/06/2021 20:10:07 |
![]() 339 forum posts 7 photos | Robert , Suggest you may also find ex Myford Nottingham engineers Darren and Pete helpful , if they still available , via [email protected] 07790 364189 , all as described on page 2 of forum post Myford Lathe Service from 14/03/2012. Hope this helps . Trevor |
Robert Butler | 13/06/2021 20:54:32 |
511 forum posts 6 photos | Dear John & Niko thank you for your responses. The metric screw is perfect, the cyclical issue was with the first imperial screw and nut, I think the screw and nut were inaccurately machined which meant the backlash set by the collared nut varied along the length of the screw. The PX pinion does not affect backlash. I have just tried the set up with the the replacement imperial screw and nut but omitting the PX drive pinion and the screw operates satisfactorily. With the pinion in place the screw is fine until pushing the nut the final 1/8" or so into position. whether this is the nut or pinion which is having some effect and why is unclear. The pinion and the exposed gear in the apron are undamaged as is the key which is an integral part of the PX pinion and it slides freely on the screw. I have not yet slackened the apron and am reluctant to do this following the doctrine of unintended consequences. The emboldened text in inverted commas is quoted from Myford's instructions. My view is that if the nut and screw are concentric they should fit. Puzzled.com Thank you for your help so far. Robert Butler
Edited By Robert Butler on 13/06/2021 21:11:13 |
Robert Butler | 13/06/2021 21:08:51 |
511 forum posts 6 photos | Trevor Thank you, I do have his contact details, he serviced the lathe back in 2017 before my conversion project. If the forum members are unable to help me solve the problem I will contact him. Robert Butler |
John P | 14/06/2021 09:30:06 |
451 forum posts 268 photos | Posted by Robert Butler 13/06/2021 18:30:25 I have just tried the set up with the the replacement imperial screw and nut but omitting the PX drive pinion Hi Robert, It seems as if you are nearly there ,try fitting the power cross feed pinion with the
John |
Robert Butler | 14/06/2021 09:34:38 |
Thank you, sounds like a good suggestion but it may be the weekend before I can try this. Robert Butler |
Robert Butler | 29/06/2021 22:34:15 |
511 forum posts 6 photos | An update of sorts. I tried fitting following Myford's instructions exactly including reluctantly loosening the apron screws - no improvement whatsoever! I then tried John Paces suggestion, fitting the nut with the PX pinion in place onto the apron and then operating the PX with the main leadscrew handwheel, the pinion showed no signs of binding and rotated freely. As soon as the leadscrew was inserted taking care to mesh the pinion with the leadscrew slot the screw binds. Reinstate Metric nut, screw etc perfect. If the Imperial nut is assembled on to the screw and the pinion fitted the screw works fine and the pinion moves without any signs of sticking or binding it is only when fitted to the apron there is a problem. I think John may be on the right track with the depth of the slot, but cannot see an easy way of establishing the slot depth on either feedscrew to confirm this. Failing this I think there may be an axial alignment issue with the feedscrew/nut as without using force for fear of causing damage the issue is cyclical. I would appreciate any further suggestions please. Robert Butler |
John P | 30/06/2021 11:10:22 |
John |
Robert Butler | 30/06/2021 11:51:05 |
511 forum posts 6 photos | Dear John thank you very much for your further advice I will investigate, hopefully tonight and report back. Robert Butler
Robert Butler | 04/07/2021 18:21:36 |
511 forum posts 6 photos | Dear John A report back, I have examined the gap in the slot of the imperial leadscrew with the key having assembled the nut onto the screw and fitted the gear/bearing as you suggested and illustrated in your sketch, there is adequate clearance. I repeated the exercise with the metric screw, nut, gear bearing and the clearance is the same (no means of measuring accurately) with a clearly visible "gap" along the length of both screws. I again refitted the metric screw and it is perfect. For what it's worth, i think there is a lack of concentricity with with the screw, the nut or bore in the saddle? Thank you for the diagram and assistance so far. Robert Butler
Edited By Robert Butler on 04/07/2021 18:26:53 |
John P | 04/07/2021 19:41:55 |
451 forum posts 268 photos | Hi Robert , "For what it's worth, i think there is a lack of concentricity with the screw, the nut or bore in the saddle?" When you look at the product on the Myford page they claim to lap the nut and the screw together When you refit the the screw and the bracket as their advice is to leave the screws
Robert Butler | 04/07/2021 20:38:28 |
511 forum posts 6 photos | Hello John Thanks once again for your reply. The imperial nut is some kind of brass rather than the metric nut which is steel. I am aware the nuts and screws are lapped but I'm not sure this is done with a brass nut as I think the abrasive would embed itself in brass thereby unintentionally continuing the lapping process! The screw and nut seem well made and before attempting to fit the nut and screw to the saddle/cross slide run smoothly. The nut is a good fit in the saddle and I can't see anyway it can be adjusted up or down before the final tightening of the nut. I think Myford's suggestion to slacken the apron was a shot in this direction - but the apron still requires tightening, I tried this without any improvement even with the screws slack and thinking this through it is a saddle/cross slide issue not an apron issue. Myford have promised to get back to me this week as their man was on holiday last week. Many thanks Robert
John P | 04/07/2021 21:44:20 |
451 forum posts 268 photos | Hi Robert, It is quite possible for them to lap even with a brass or bronze type nut ,yellow label Timesaver abrasive is used just for this ,quite useful stuff and does not embed and can be used on whitemetal bearings. Hope that Myford will be able to help you ,let us know how you get on. John |
Robert Butler | 18/07/2021 21:55:37 |
511 forum posts 6 photos | Hi John An update, Myford suggested I return the screw and nut for appraisal, which I did. They detected tightness and suggested it was borderline on tolerance and sent a replacement "original" Myford screw and nut which I fitted today. The replacement is significantly better but lacks the silky smooth action of the metric screw and nut. I can't get it down to virtually nil backlash either. I am reluctant to concede that it may bed in as I feel it should work out of the box. Robert Butler Edited By Robert Butler on 18/07/2021 21:56:17 |
