Ady1 | 03/05/2021 00:07:02 |
![]() 6137 forum posts 893 photos | Just got a new pal, Drummond number 2 which was saved from a house clearance not too far from me Plenty of work to do to get her going again but problem number one was a nice looking original scroll chuck still holding its workpiece from possibly decades ago and not keen on letting go Suggested solutions to this problem are entertained, I have a large hammer ready to batter the workpiece from side to side The register part has marks which look like they've used some sort of grippy thing to screw her on too, tsk tsk tsk Edited By Ady1 on 03/05/2021 00:09:36 |
Michael Gilligan | 03/05/2021 00:34:54 |
![]() 23121 forum posts 1360 photos | Clean all the accessible grime out of the joint and carefully apply PlusGas ‘formula A ‘ dismantling fluid. Whilst it is seeping-in ... make or buy a C-spanner to fit. After a couple of days ... thump the spanner with your big hammer. If that doesn’t work ... part-off that workpiece and drill/bore it until it’s just a tube of shim. [which should relieve the pressure on the jaws] and try again. MichaelG.
Ady1 | 03/05/2021 01:13:17 |
![]() 6137 forum posts 893 photos | So I put a c spanner into the hole and hit it with a hammer and the chuck goes round and round and do I whack it with the spanner hanging down on the nearside or the farside? I've got a scroll chuck somewhere, hopefully they all work the same way Edited By Ady1 on 03/05/2021 01:32:52 |
John Olsen | 03/05/2021 04:41:55 |
1294 forum posts 108 photos 1 articles | You need a spanner on one of the chuck jaws and a C spanner in the hole. Make sure one is braced against something solid and tap the other one in the correct direction. The should be after applying some sort of penetrating oil as suggested above. Figuring out the correct direction may be tricky unless you can see part of the scroll somewhere. John |
Michael Gilligan | 03/05/2021 05:44:06 |
![]() 23121 forum posts 1360 photos | Posted by Ady1 on 03/05/2021 01:13:17:
MichaelG |
DC31k | 03/05/2021 07:29:44 |
1186 forum posts 11 photos | Is there any utility in removing the chuck from the machine first and then submerging in a bucket of something penetrating? The turning the stock from the jaws is a very good plan as then it does not matter which way you turn it - you just need to induce some movement in the chuck scroll. Extreme, desperate measure might be hot caustic soda: not only will it dissolve the aluminium stock, but it will help with internal gumming up. |
Ady1 | 03/05/2021 08:18:01 |
![]() 6137 forum posts 893 photos | I found my cowells chuck, looked at the scroll and managed to get a result Put a block of wood from the lathe bed to beneath the chuck jaw, no violence required Edited By Ady1 on 03/05/2021 08:23:37 |
Ady1 | 03/05/2021 08:21:30 |
![]() 6137 forum posts 893 photos | It also occurred to my teeny brain that I should have been using this system for my unimat scroll chuck from the very beginning and ignoring the front chuck body hole The commonly used "two bar system" plays havoc with my damaged thumbs duh Edited By Ady1 on 03/05/2021 08:24:12 |
Michael Gilligan | 03/05/2021 09:06:32 |
![]() 23121 forum posts 1360 photos | Well that was easy !! I only suggested a C-spanner and a hammer because the holes looked rather shallow and if it was seized then you would risk bruising them with a tommy-bar. MichaelG. |
Ady1 | 03/05/2021 09:19:43 |
![]() 6137 forum posts 893 photos | The C spanner is the best most professional approach I'm just being impatient, I want my new boy toy up and running sooner rather than later |
Nigel McBurney 1 | 03/05/2021 11:07:33 |
![]() 1101 forum posts 3 photos | My Burnerd lever scroll chuck came brand new,and had a round tommy bar in th box,this fits the 3 holes on the periphery |
