Help in identifying thuis set of tools please
Paul Barter | 26/04/2021 14:52:57 |
112 forum posts 8 photos | Hello all, Back again to acess the knowledge These rods are marked with sizes, yet the tduplicate wo inch and one inch are consistently two thou over ie 1.002 and 2.002.The two micrometer heads have domed ends and are graduated for tenths.The rods have flat ends on truncated cones.Can anyone identify the name and use of these please? |
Paul Barter | 26/04/2021 15:04:37 |
112 forum posts 8 photos | Just to add to my post the two adjustable heads measure 3.625 when set to zero on the barrels were these for some very particular measuring process like go no go gauges? Thanks again for any suggestions Paul |
Howard Lewis | 26/04/2021 15:15:08 |
7227 forum posts 21 photos | Most probably an internal micrometer set, possibly with the heads in need of resetting to remove the 0.002 error. Which raises the question, before making ANY adjustments, of how accurate are the devices used to measure the overall length? Have they been checked against length standards or slip gauges, to confirm their accuracy? Do any, or all of the other extension rods show the same +0.002" ? If adjustment is required, the spanners with which to do it are there Howard |
Nick Hughes | 26/04/2021 15:18:18 |
![]() 307 forum posts 150 photos | They are End Measuring Rods, used on a Jig Boring Machine. |
Paul Barter | 26/04/2021 15:35:44 |
112 forum posts 8 photos | Thanks to you both or the swift response, the rods are not adjustable and were measured with Mitutoyo micrometers set to to slip gauges so I am surprised at the consistency of the apparent error. also the rods marked 8 and 4 inch are also duplicated. A Jig boring machine is beyond my skill set, but how would these be used please Nick? is 3.5/8 of particular significance and why two? Thanks again to you both Paul |
Nick Hughes | 26/04/2021 15:52:58 |
![]() 307 forum posts 150 photos | Have a look from page 10 and on of this Pratt and Whitney brochure :- Pratt & Whitney Jig Borers Circular 513 If the link fails, PM me and I'll send you the PDF Nick Edited By Nick Hughes on 26/04/2021 16:01:40 |
Paul Barter | 26/04/2021 16:06:02 |
112 forum posts 8 photos | Thank you very much Nick, the link worked perfectly and I shall enjoy reading all of it. The penny has dropped! I doubt that I will ever use these as intended but they were too interesting to be left at the car boot! In any event I now have a set of standards up to 12Inches Thanks Paul |
Clive Foster | 26/04/2021 16:13:29 |
3630 forum posts 128 photos | As Nick says these are used in jig borers to accurately set distances. Often toolroom class milling machines had a trough on the front of the table to carry them when doing accurate work. Even Bridgeports had an accessory to enable their use. The adjustable heads are nominal 3.625" long. They should be set to read 3.625" on zero by the usual method of turning the micrometer sleeve. However some firms preferred to leave the sleeve in a fixed poistion and note the error. My set, obtained for a specific maybe job but never used, has calibration labels for the two heads. One says 3.6258 an one 3.6250. If I ever use them I shall sort that so both are calibrated to 3.6250 The length bars should be accurate to ± 0.00005" at standard temperature. That equates to less than 0.0001 error band. No idea why you are measuring one or 2 thou over. That said out in the real world you'd expect regular calibration with last time details to be in the box These would normally be used with a tenths thou indicator. See the picture half way down this page :- **LINK** , http://www.lathes.co.uk/bridgeport/page3.html for the Bridgeport accessory set up. Clive PS Nick sent a very interesting link whilst I was typing making the above post pretty much redundant! I've grabbed the P&W information from Nicks link too.
Edited By Clive Foster on 26/04/2021 16:18:49 |
Michael Gilligan | 26/04/2021 17:36:16 |
![]() 23121 forum posts 1360 photos | Posted by Nick Hughes on 26/04/2021 15:52:58:
Have a look from page 10 and on of this Pratt and Whitney brochure :- . Clever use of the dial indicator : . MichaelG. |
