choochoo_baloo | 05/04/2021 21:44:56 |
![]() 282 forum posts 67 photos | Hello all, I remembered I have this Wesco can (1960s vintage I think?). However the spout has snapped. It still pumps well! Is it possible to buy replacment spouts? It looks like the new spares have a much smaller thread to attach to the can. The Wesco has a retaining collar - see picture. I do prefer to repair and re-use if possible. Especially compared to the poor performance of the modern Chinesium ones I've used Any suggestions are very welcome. Thank you. |
Mike Poole | 05/04/2021 22:19:09 |
![]() 3676 forum posts 82 photos | I would think you could turn up a replacement from nylon or delrin, the ferrules for the tube are available from classic bike spares outlets but you need to fashion a crimper. The tube can also be replaced as it tends to go brittle after long service, certainly when used for petrol it does. Mike |
martin haysom | 05/04/2021 22:31:25 |
![]() 165 forum posts | when mine broke i made the replacement out of a piece of copper brake pipe |
Jeff Dayman | 05/04/2021 22:51:07 |
2356 forum posts 47 photos | +1 on making a metal replacement. To re-use the original nut, a washer or disc of same material as delivery tube could be found or turned on the lathe, to fit the inside dim of the nut. Make the disc ID a close clearance fit to the delivery tube. Silver solder or bronze weld tube to disc, bend tube along the length or at tip to suitable jaunty angle , and there you are. The outer end of the tube could be peened over to make a smaller ID delivery nozzle if some more energetic squirting is needed. Copper tube, brass tube, or any sort of brake line out of a car would all make good delivery tubes. Wise to check hole in disc and tube are open after solder / braze op. Edited By Jeff Dayman on 05/04/2021 22:51:48 |
Brian Morehen | 06/04/2021 08:00:46 |
![]() 191 forum posts 11 photos | Have bought replacement in the past , a few years ago , today a possible big question. |
Robert Butler | 06/04/2021 11:17:31 |
511 forum posts 6 photos | Try Googling Wesco Oil Can Spouts - from £2-00 upwards Robert Butler |
Circlip | 06/04/2021 11:29:12 |
1723 forum posts | " To re-use the original nut, a washer or disc of same material as delivery tube could be found or turned on the lathe, to fit the inside dim of the nut. Make the disc ID a close clearance fit to the delivery tube." That brought back memories of the spouts in the top of Model Aircraft/Boats Diesel fuel cans. Regards Ian. |
