Wavy Parallels
Clay Jones18/02/2021 17:52:42
37 forum posts
Hi all. Well the workshop is prepped, the WM16B is on order, forum has been scanned to an inch of its life to soak up your obvious impressive knowledge and a nice delivery of tooling has been purchased. I have bought some 8mm parallels but keep noticing Wavy Parallels. Question is are they handy and more importantly why and when would I use them and just how precision are they.
Clay
Oldiron18/02/2021 18:01:19
1193 forum posts
59 photos
Hi Clay. Wavy parallels are very handy for use with thin work pieces as they will deform within reason to the width needed.
regards
Clay Jones18/02/2021 18:15:35
37 forum posts
Many thanks.
Clay Jones18/02/2021 18:15:36
37 forum posts
Many thanks.
Rod Renshaw18/02/2021 18:25:54
438 forum posts
Hi Clay
In addition to the use described above by Oldiron, it is useful sometimes to use accurate "normal" parallels to rest the work on, and use slightly lower wavy parallels between the normal parallels to keep the normal parallels from toppling over.
Rod
Clay Jones18/02/2021 18:39:01
37 forum posts
Just what I find so helpful about this forum, simple but clever tips like that, thanks Rod.
Oldiron18/02/2021 18:42:47
1193 forum posts
59 photos
Posted by Rod Renshaw on 18/02/2021 18:25:54:
Hi Clay
Rod
In the absence of wavy parallels a piece of foam rubber makes a good substitute for that purpose.
regards
Paul Lousick18/02/2021 21:13:09
2276 forum posts
801 photos
"Band-it" strapping is very useful in the workshop. Cut into small lengths as shims to raise the height of lathe tools and bent into a U-shape as a spring between the parallels to keep them pressed against the vice jaws.
Paul
Clive Foster18/02/2021 21:26:56
3630 forum posts
128 photos
If you don't have Band-it strapping sections of worn out or broken hacksaw blade with the teeth ground off are also make good shims.
Hardboard strip against one vice jaw is great for improving grip on something a bit rough or slightly out of parallel. It squidges well enough to tahe up the diffrences but still firm enough for a good grip. Just remember to measure from the other jaw!
