tailstock dro by duncan webster
peter ravenscroft | 09/02/2021 18:30:29 |
100 forum posts 3 photos | hello is it posible to have a copy of the drawings and the code for the tailstock dro in issue 301 regards peter |
duncan webster | 09/02/2021 18:33:14 |
5307 forum posts 83 photos | send me a pm and I'll forward the code and drawing. The drawing is pretty basic, only enough for me to make it, but it will give you the idea. Will need fine tuning to suit whatever lathe you have |
Derrick Ardron | 09/02/2021 20:08:21 |
1 forum posts | Very interesting article and looks like not too difficult as a first proper Arduino project. Could I also request a copy of the drawing and the code., Many thanks Derrick |
Matt Harrington | 09/02/2021 23:46:49 |
![]() 212 forum posts 16 photos | Duncan, I'd be interested as well. Do you think it is possible to hook up to a Sino DRO? Regards, Matt |
Greensands | 10/02/2021 09:22:53 |
449 forum posts 72 photos | Hi - Could you also send a copy to me. Looks to be an ideal starter project. Thank you |
duncan webster | 10/02/2021 12:20:16 |
5307 forum posts 83 photos | I've sent details to Roy Oxley and Michael Gilligan. Others who have requested via pm or above need to send me their email address by pm (click on 'message member' ) . I've tried to send it to Emgee, but it wouldn't accept the email address. Would it connect to a Sino? Most scales increment on 0.005mm resolution, so you'd need to arrange 200 edges per mm travel of tailstock. My set up gives 1600 edges for 0.3", which is 209.973 edges per mm. However you could change the belt drive ratio gear it up, or the software could be arranged to do a conversion, but it would be a bit involved. Belt ratio would depend on leadscrew pitch, if you had a metric pitch it might work out easier edit to get rid of smiley,
Edited By duncan webster on 10/02/2021 12:21:06 |
Michael Gilligan | 10/02/2021 13:14:25 |
![]() 23121 forum posts 1360 photos | Thanks in anticipation, Duncan [ it’s not yet arrived ] ... Much appreciated MichaelG. |
Ady1 | 10/02/2021 15:54:14 |
![]() 6137 forum posts 893 photos | If you're going to fire files about then try and keep them under 20MB |
duncan webster | 10/02/2021 16:49:18 |
5307 forum posts 83 photos | well under 500kb I think I've replied to all who have contacted me so far, if not please pm me again. Don't forget to attach your email address, I can't attach files to a reply on the forum |
Michael Gilligan | 10/02/2021 17:11:17 |
![]() 23121 forum posts 1360 photos | Posted by duncan webster on 10/02/2021 16:49:18:
well under 500kb I think I've replied to all who have contacted me so far, if not please pm me again. Don't forget to attach your email address, I can't attach files to a reply on the forum . Thanks, Duncan ... regrettably, I have still not received a message. MichaelG. |
Michael Gilligan | 11/02/2021 10:04:29 |
![]() 23121 forum posts 1360 photos | For the benefit of anyone else who uses an iOS device for their eMail : Duncan’s nicely annotated code < TailDRO_4.ino > opens tidily in an App called DraftPad MichaelG. . https://apps.apple.com/gb/app/draftpad/id358067114 Edited By Michael Gilligan on 11/02/2021 10:06:04 |
peter ravenscroft | 11/02/2021 18:14:33 |
100 forum posts 3 photos | hi duncan many thanks for taking the time and the trouble to send me the filesregards peter |
peter ravenscroft | 20/03/2021 14:04:40 |
100 forum posts 3 photos | hi duncan many thanks for the files i have built one and it works a treat clever programing regards peter |
