Sheared screw in wood
steamdave08/02/2021 10:48:16
526 forum posts
45 photos
Trying to remove wood screws from a panel door, I have sheared two of them flush with the surface behind the door handle.
They are of the hardened type, 3.2mm diameter and there is 20mm stuck in the wood. Any suggestions on how to remove the screws please?
My thought at the moment is to make a core drill that will just pass over the screw and OD about 4.5 - 5.0mm. When deep enough, i will try and get long nose pliers on the end and try and break off the peg. Afterwards I will fill the hole with a dowel.
The Emerald Isle
Grindstone Cowboy08/02/2021 11:31:48
1160 forum posts
73 photos
Sounds like the best idea to me yes
A suitably sized piece of tube (ID just big enough to fit over the screw so it guides it) with teeth filed on the end should suffice.
Rob
Frances IoM08/02/2021 11:35:33
1395 forum posts
30 photos
use a soldering iron to apply significant heat to the top of the screw once you have dug out enough surrounding wood to allow the pliers to get a grip - should break any grip in the wood
noel shelley08/02/2021 12:09:42
2308 forum posts
33 photos
I go with robs idea ! Good luck ! Noel.
bernard towers08/02/2021 13:19:33
1221 forum posts
161 photos
Don’t forget to make crossgrain dowels to give the screws something to grip!
steamdave09/02/2021 15:08:00
526 forum posts
45 photos
Job done!
Followed G.Cowboy's suggestion of using a piece of tube - stainless in my case - and just filed 3 teeth on the end. Coped OK with the soft wood.
I used a normal piece of dowel to fill the (6mm) hole and the screw gripped just fine.
The Emerald Isle
Howard Lewis09/02/2021 17:39:51
7227 forum posts
21 photos
Thanks for the end result.
Glad that you succeeded.
