Milling machine
Sean Stimpson | 02/02/2021 20:26:50 |
31 forum posts 14 photos | Hi all looking at advice of downsizing from a vari speed bridgeport looking at alexander master tool maker dekcel fp1 size what are people's views downsizing as moving thanks |
Phil P | 02/02/2021 21:47:57 |
851 forum posts 206 photos | You could do a lot worse than an Alexander / Deckel, but make sure you buy one that is "tooled up". For many years I ran an Adcock Shipley 1ES with a Bridgeport vertical head grafted onto the overarm, the problem was it was too tall to fit my garage at the time so when I got the chance of my Alexander it was a no brainer. Have a look at the gear hobbing thread for some inspiration. https://www.model-engineer.co.uk/forums/postings.asp?th=170858&p=2#PostTop Phil |
Neil Lickfold | 02/02/2021 22:09:23 |
1025 forum posts 204 photos | The FP1 machines are very noisy. Need earmuffs just to hear yourself think. They are a nice and very versatile machine though. From thread milling to small hole drilling etc. Like been mentioned it is the accessories that really make the machine. I like the aspect of the horizontal work as well as the vertical work that can be done in the one set up. |
Phil P | 02/02/2021 22:24:43 |
851 forum posts 206 photos | The Alexander is only noisy when running at high speeds, but I have a poly vee belt driven separate high speed head which I use 90% of the time so noise is no longer a problem. Phil |
Chris Evans 6 | 03/02/2021 08:55:09 |
![]() 2156 forum posts | I suppose it all depends on what type of work you do for most of the time. I run a varispeed Bridgeport and love the ability to do motorcycle related work. ( I am not a model maker) If I had to downsize a smaller machine would do 80% of the work but I would want a machine with a decent quill for drilling and boring. As said above the Deckle style machines need to be fully tooled. |
